Oil starved pistons?
Old Oct 16, 2004 | 06:56 PM
B-B-K's Avatar
Default Oil starved pistons?
Im planning on building a GSR block with a B16 head, and I was wantin to use some PR3 pistons. My boy seized his B16 cuz of an oil leak, thats another story, but I was wondering if I could use his psitons. The head is what seized, the cam cap on the intake side closest to the cam gear is what welded itself to the cam. We took the head off and the block "looked" fine. Im wondering if there is any hidden "danger" I should look for on the psitons. Im going to take the pistons out soon and see if the skirts are scored. If the skirts look fine would I be able to use the pistons?
Basiclly, Im wondering if there isnt any damage on the pistons will they be ok to use?
Thanks for any info, sorry if this sounds like a dumb question.
Matt
Old Oct 16, 2004 | 07:49 PM
boosted k20's Avatar
Default Re: Oil starved pistons? (B-B-K)
i wouldnt use any used pistons in another block. the pistons will take shape to the cylinder that there in. it wont be too much of a difference in shape from brand new ones but I personally wouldnt put n e used pistons in my block. just get a set of new PR3's. whats it gonna cost ya? like a bill?
Old Oct 16, 2004 | 10:37 PM
99skunkedSi's Avatar
Default Re: Oil starved pistons? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt use any used pistons in another block. the pistons will take shape to the cylinder that there in. it wont be too much of a difference in shape from brand new ones but I personally wouldnt put n e used pistons in my block. just get a set of new PR3's. whats it gonna cost ya? like a bill?</TD></TR></TABLE>
true, i wouldn't use them. just spend the money on some new ones! if your gonna build a block don't rush and definally don't take short cuts! you only want to build it once right!?
Old Oct 17, 2004 | 12:01 AM
DOHCtorTHRUST's Avatar
Default Re: Oil starved pistons? (99skunkedSi)
depending on how many miles on your motor, you may want to think of getting oversized pistons instead of replacing it with standard size pistons....i wouldnt waste a rebuild with used standard sized pistons...
Old Oct 17, 2004 | 05:02 AM
93supercoupe's Avatar
Default Re: Oil starved pistons? (DOHCtorTHRUST)
I used old PR3's im my LSvtec, and it runs fine with good comp. all the way across.Just rering it and have a blast
ceearexx
Jan 27, 2013 10:41 AM
Wheelman-CZ
Jan 7, 2008 12:52 AM
Bgesy
Aug 24, 2006 04:28 AM
bluedelsol
Jun 28, 2003 10:47 AM
robhamaliuk
Jan 24, 2003 10:17 AM
