Which Rings to use?
Old Oct 16, 2004 | 04:15 PM
hybridnorth's Avatar
Default Which Rings to use?
So here's the problem, I used JE Rings on my last motor
did the hard break in, and one of the rings broke.
What rings are guys using on their all motor setups? mine's nothing crazy, b16,ctr pistons, gsr head
TIA
Old Oct 16, 2004 | 04:31 PM
Runnerdown's Avatar
OEM
Old Oct 16, 2004 | 07:22 PM
99skunkedSi's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">OEM</TD></TR></TABLE>
cam you get oem rings for over sized pistons? also whats the word on "total seal" rings
Old Oct 16, 2004 | 08:10 PM
Default Re: (99skunkedSi)
anything better than OEM?
I know factory honda is top notch,but there should be something better out there
Old Oct 16, 2004 | 11:09 PM
HeadPorter's Avatar
total seal, give them your setup and use plans and they will give you what you need.
Old Oct 16, 2004 | 11:15 PM
Default Re: (HeadPorter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeadPorter &raquo;</TD></TR><TR><TD CLASS="quote">total seal, give them your setup and use plans and they will give you what you need.</TD></TR></TABLE>
yeah but do they cause premature wear?
Old Oct 17, 2004 | 04:44 AM
Runnerdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99skunkedSi &raquo;</TD></TR><TR><TD CLASS="quote">
cam you get oem rings for over sized pistons? also whats the word on "total seal" rings</TD></TR></TABLE>
He says he has ctr pistons. In that case they would be no larger then 81.25mm. That ring size is available from honda of course.
Old Oct 17, 2004 | 06:47 AM
turbociv's Avatar
I use hastings rings all the time. No problems and theywork great.
Old Oct 17, 2004 | 05:35 PM
Sobe_Death's Avatar
i use totalseal rings, and like they are designed, they have kept blow by and leakdown around the rings to a minimum. i love them(except the price) and would either use them or oem honda
Old Oct 17, 2004 | 06:17 PM
Default Re: (Sobe_Death)
thanks guys
im using stock bore ctr pistons
i heard that total seal dont like nitrous, im not gonna use nitrous on these pistons
hastings is good, but you gotta baby those rings right? for the first 1500 miles approx.
Old Oct 17, 2004 | 08:37 PM
Sobe_Death's Avatar
total seal rings are actually prime for the increased combustion pressures of nitrous and other forced induction as well
Old Oct 17, 2004 | 08:40 PM
UnKnownUser's Avatar
Does honda make 86mm piston rings?
Old Oct 18, 2004 | 06:11 AM
MenaceL.A.671's Avatar
Default Re: Which Rings to use? (hybridnorth)
i have extreme total seals on my itr piston standard bore and they work hella good with NO problems....i think this extreme total seals are like the latest **** they made.... peaz...
Old Oct 18, 2004 | 08:01 AM
svistras's Avatar
Default Re: Which Rings to use? (m2slsvtec)
does anyone else has done the hard-break in , thing with success, using OEM rings?
Old Oct 18, 2004 | 08:26 AM
DonF's Avatar
Default Re: Which Rings to use? (svistras)
D id you buy " file fit rings" and not check the end gap? What was the end gap? Rings do not normally break without a reason, stock piston maybe, but not rings unless they are butting the ends.
Old Oct 18, 2004 | 10:14 AM
svistras's Avatar
Default Re: Which Rings to use? (DonF)
yeah but he said he did the hard break-in , and i was considering to do the same after i build my motor, is there a possibility these rings cant handle this way of break-in?
Old Oct 18, 2004 | 12:45 PM
Sobe_Death's Avatar
not if the end gap is correct...
Old Oct 18, 2004 | 08:42 PM
yes these were file fit rings
i gapped all the rings to spec. je spec.
i spent the better prt of a day sitting there filing each ring
so total seal works, aswell as hastings
i was going for a chrome moly ring, there another type out there ____ moly, does anyone know or am i sniffing too much varsol
Old Oct 20, 2004 | 07:33 PM
Default Re: (hybridnorth)
ttt
W C L
Oct 17, 2005 01:51 PM
quik1
Jun 19, 2004 06:33 PM
quik1
Jun 9, 2004 07:48 PM
PHiZ
Jun 9, 2004 06:01 PM
vtec.dc2
Sep 24, 2003 09:06 AM
