Compression issues 0 on number 1 after over rev.
Old Oct 16, 2004 | 03:03 PM
civicaleg's Avatar
Default Compression issues 0 on number 1 after over rev.
Like the title says
B16a2
number 1 0
number 2 190
number 3 220
number 4 210
Bent valve or what?
number 1
number2,3
head
Modified by civicaleg at 5:55 PM 10/17/2004
Modified by civicaleg at 5:57 PM 10/17/2004
Old Oct 16, 2004 | 03:04 PM
chris_m's Avatar
* B A N N E D *
Default Re: Compression issues 0 on number 1 after over rev. (civicaleg)
dead cylinder. Pull your head your gonna find alot of damage
Old Oct 16, 2004 | 03:05 PM
civicaleg's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (alld16a)
Doesn"t make any noise still revs good.
Old Oct 16, 2004 | 03:27 PM
SiR831's Avatar
ouch. keep us posted
Old Oct 16, 2004 | 03:38 PM
PyroProblem's Avatar
Do a leakdown test.That will tell you exactly what is bent/broken and not holding compression...
Either way,sounds like the head is gonna have to come off. Hope its only bent valves!
Old Oct 16, 2004 | 03:45 PM
civicaleg's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (PyroProblem)
Thanks, I am pulling the head in the morning just to be sure.
Old Oct 16, 2004 | 05:37 PM
skunk2eg's Avatar
ouch
Old Oct 16, 2004 | 07:55 PM
boosted k20's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (skunk2eg)
i bet u cracked one of ur valves? do u have any upgraded valves in ur car? skunk2 valves are known for break n which will give u zero compression on that cylinder
Old Oct 17, 2004 | 03:00 PM
civicaleg's Avatar
got some pictures and up date, exhaust valves did hit pistons
Old Oct 17, 2004 | 03:10 PM
IN VTEC's Avatar
Check leakage with carb or brake parts cleaner, or take it to a machine shop that can test it with a port leak-down tester. That will tell you the minimum number of valves you'll need to buy.
Old Oct 17, 2004 | 03:21 PM
civicaleg's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (IN VTEC)
I just bought a good jdm b16 complete. I am taking this gsr head to machine shop. then selling after fix.
Old Oct 17, 2004 | 04:22 PM
johnzm's Avatar
hey, what did it rev to?
Old Oct 17, 2004 | 04:30 PM
civicaleg's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (johnzm)
between 11k and 12krpm
Old Oct 17, 2004 | 04:45 PM
johnzm's Avatar
looks like u came out lucky- no cracks or holes
was it stock valvetrain?
Old Oct 17, 2004 | 04:55 PM
11K-12K?? did u misshift. i remeber i mishifted once. i was on the phone and at redline on my LS (6.8K) and was go n to shift from 4th to 5th but ended up go n into third. i overevved the motor but i clutched down really qucik. i seen my tach go all the way past 8K. **** was scary as hell. car has been driving okay since then. i should do a leak down test on my motor... just to make sure. this happened about 3 weeks ago
Old Oct 17, 2004 | 05:39 PM
UnKnownUser's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (boosted k20)
11-12k rpm are you nuts dam whats your setup?
Old Oct 17, 2004 | 05:52 PM
civicaleg's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (LSVTEC DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC DC4 &raquo;</TD></TR><TR><TD CLASS="quote">11-12k rpm are you nuts dam whats your setup?</TD></TR></TABLE>
shifted from 3rd to 2nd last time i looked at the tach was 9500. slammed then clutch to save, to late.
running mild build, zex springs and retainers, zex stage 2 cams,mild port work, shaved gsr head ,skunk2 mani, 70mm bbk, 310rc injectors, stock B16a2 bottom end. GSR tranny w/phantom grip, ACT clutch w/prolite flywheel. P28 skunk2 program no rev
Modified by civicaleg at 9:09 PM 10/17/2004
Old Oct 17, 2004 | 05:56 PM
8krdline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicaleg &raquo;</TD></TR><TR><TD CLASS="quote">
My friend accidently did that twice in his b16 and it still ran fine, just not to 9500 but the rpm needle did go off the tach
Old Oct 17, 2004 | 06:07 PM
civicaleg's Avatar
Default Re: Compression issues 0 on number 1 after over rev. (8krdline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8krdline &raquo;</TD></TR><TR><TD CLASS="quote">
My friend accidently did that twice in his b16 and it still ran fine, just not to 9500 but the rpm needle did go off the tach</TD></TR></TABLE>
This was the first and only time with high lift cams.
00Red_SiR
Feb 25, 2007 05:19 PM
madjdmy0
Oct 15, 2005 11:37 AM
1999all_motoR_teg
Jul 31, 2005 06:21 PM
Drag-On23
Aug 29, 2003 04:04 PM
gavhowe
Aug 2, 2002 07:03 AM
