VALVE COVER BOLT and IGNITION MISS FIRE
I have a valve cover bolt on a d15 vx engine brake off. I know you can drill on it with a reverse bit but any other options? Just bought the car and waiting to finish my h22a engine to swap in.
also i have a missfire hard when i put a load on the engine. at first i thought it was the clutch but it only happens when the car warms up. i have changed plugs which were fouled at the botton of plug with carbon so i'm thinking ignition problem. ngk v power plugs
changed wires to omni
changed dist cap and rotor borg warner and i just bought a coil replacement borg warner i getting ready to install.
compression
cly#1 155
cly#2 170
cly#3 150
cly#4 155
the engine has 155k on it and body.
i have changed oil 10-30/05-40 wieght mixed with lucas lubercaints
this happend on the first gas tank of the car too. so this sucks
i ran 91 octane on it maybe that to much.
but when it warms up it miss fires hard when i get on it and then die's down about 3-4k but is still there. I also chagned fuel filter but the original one took off the holes on the bolt lined up with the out let tube to the engine. this one is about 45' off the intake line but i did see a little resorvoir grooved in the the outlet attachment so i did't worry that much. but i'm going to change it to the old one just to check and i'm got to put in the coil if the filter doesn't check out right and can anyone get a service manual for this not chilton I need more specific 92 civic vx.
i know helms inc has them but there $60 i know people sell them on cd but i need a book and not a replica or copy. let me know what you guys think? 913-638-2786 is my cell so if you can help with the problem let me know.
Also this is my first posting. I help my uncle run jdm warehouse. so if you guys need anything don't hesiate to ask. Engines b-series-h-series some type-r s200o motors f20c, body Parts and clips, ect....
i have some used 92-95 tein flex dampeners for 450 plus shipping. Just a thought.
Any help would be great.
Thanks
Jason Buckner
Anarchy MotorSports
compression
cly#1 155
cly#2 170
cly#3 150
cly#4 155
Thanks
Jason Buckner
Anarchy MotorSports
i just ran a tru ignition sensitivity test and all wires are firing fine.
while running i pulled the one wire out at a time then replace to see if the engine would lose power. all lost the same amount of rpms of power.
so i will change filter and post back.
how do i post pics i got a digital
just changed coil ingition in distibutor car fired right up. noe for a test drive?????
ok it won't let me post anymore but i did the test drive....and.......victory.
no missfire now i have that valve bolt
Thanks
Jason Buckner
Anarchy MotorSports
Modified by 92 CIVIC HATCH VX at 4:40 PM 10/16/2004
Thanks
Jason Buckner
Anarchy MotorSports
pchornung
Aug 10, 2007 08:52 AM
SkoundrelUSA
11
Feb 7, 2006 04:46 PM
