problems with the driver's window, lil help, please?
i have a 91 crx dx, it's always had this problems since i've had it. when you roll the window up, i get this gap between the window and the frame towards the rear. did some searching, and a lot of people have had trouble with their window regulators. does this look like a regulator problem?
above shots...
front shot, where it is...
where it should be...
i've already tried adjusting the bolts under the door panel, it seems more like the window itself isn't being supported fully. tia
above shots...
Hey, I had had a problem like this, what i did was take off the door panel and the window got out of place... it usually gets out of place when the frame is bent or when the screws are loose, try taking off the panel and putting it into place
it shouldnt be like my prob... i got a window from a 89-91 but what i needed is a 88.... i got gap from the front end of the window...
im pretty sure your window frame is a bit out of aligment...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">
im pretty sure your window frame is a bit out of aligment...</TD></TR></TABLE>
so does anyone know how i can fix that?
I obviously can't say for certain that your regulator is bad or not. However, I do know that after cussing a hell of a lot over a couple weeks of trying to adjust my window alignment problems on the 91, after I picked up another regulator at the junk yard...my alignment problems were gone. I'd say there's a very good chance yours is worn out.
