Went junkyarding today, need some help.
Sorry if this should be in the hybrid forum but they don't give me help fast enough. I was searching around at junkyards today because last night i crashed my civic and fucked up the door and quarterpanel. I just replaced them last summer because the previous owner hit a deer.
So i bought a fender and while searching around i found a new si hatch sitting in the yard.....and asked how much i could get the engine for. He said that one wasn't for sale but they had a 02 si with 17,000 miles and the complete swap axels and ecu, tranny and everything for $2500 .
I am wondering if that is a good deal and what kind of engine that even is? Also is this swap a hard swap and how long could i do it in? Could someone please help me
[QUOTE=civiccpedx]is that what the engine is?? How hard of swap is it? thanks for the fast response[/QUOTE
there's plenty of threads that discuss the k20 into *insert your chassis here* there are kits available for the entire swap. the price is a little high still compared to going b-series. just do a search on k20's and you find hours of info. btw 2500 is an average price for a usdm k20. i seen em lower and higher.
damn that seems like a steal to me for $2,500...but i also dont have much knowledge in k series.
search around h-t for swap info on k series its been covered...
here is some specs of the '02 si that i got from http://www.hondanews.com...
2002 CIVIC SI
SI
ENGINE
Type: Aluminum-Alloy In-Line 4
x
Displacement (cc)
1998
Horsepower @ rpm
160 @ 6500
Torque (lb.-ft. @ rpm)
132 @ 5000
Bore x Stroke (mm)
86 X 86
Compression Ratio
9.8
Valve Train: DOHC
i-VTEC
Fuel System: Multi-Point Fuel Injection
x
Emission Rating
LEV II-LEV
Direct Ignition System: Electronic with Immobilizer
x
Engine Coolant Capacity: Change (MT) (qt.)
5.4
Engine Coolant Capacity: Dry (MT) (qt.)
7.2
Engine Oil Capacity: Change without filter (qt.)
4.2
Engine Oil Capacity: Change with Filter (qt.)
4.4
Engine Oil Capacity: Dry (qt.)
5.6
110,000 mile Tune up Intervals
x
POWERTRAIN
Type: Front-Wheel Drive
x
Close Ratio Manual Transmission: 5-Speed
x
Gear Ratios: 1st
3.062
2nd
1.769
3rd
1.212
4th
0.921
5th
0.738
Reverse
3.583
Final Drive
4.764
2002 CIVIC SI
SI
ENGINE
x
Displacement (cc)
1998
Horsepower @ rpm
160 @ 6500
132 @ 5000
Bore x Stroke (mm)
86 X 86
Compression Ratio
9.8
Valve Train: DOHC
i-VTEC
x
Emission Rating
LEV II-LEV
x
5.4
7.2
4.2
4.4
5.6
x
POWERTRAIN
x
x
Gear Ratios: 1st
3.062
2nd
1.769
3rd
1.212
4th
0.921
5th
0.738
Reverse
3.583
Final Drive
4.764
thank you guys so much for the info sorry for not searching, just searching yeilds to many results and I needed to know fast. But now I will search and find good info. Thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">thank you guys so much for the info sorry for not searching, just searching yeilds to many results and I needed to know fast. But now I will search and find good info. Thanks again.</TD></TR></TABLE>
not a problem as long as you understand
good luck on your motor purchase...
k20a3 is a crappy motor until you slap a k20a or a2 head on it. Price is okay, but you will need to dump another $1 maybe 2 Gs just to get all the parts for the swap. And b16 should whoop that motor with it's stock head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">k20a3 is a crappy motor until you slap a k20a or a2 head on it. Price is okay, but you will need to dump another $1 maybe 2 Gs just to get all the parts for the swap. And b16 should whoop that motor with it's stock head.</TD></TR></TABLE>
Yeah, from what I understand that head is no good. Sounds like a good deal, but keep in mind that you are getting the weak k-motor
I would think this over before buying it. I mean you will need to buy **** load of parts for a swap, plus wiring is a bitch. And you will still prolly get owned by b series hatches.
