how do i know if mugen lip is real?
Old Oct 16, 2004 | 12:05 PM
slow motion's Avatar
Default how do i know if mugen lip is real?
Modified by slow motion at 11:39 AM 10/29/2004
Old Oct 16, 2004 | 12:42 PM
95sihb's Avatar
Default Re: how do i know if mugen lip is real? (slow motion)
The lack of money in your wallet, , but I think you much coverd it . The original receipt, and box ......... and instructions
Old Oct 16, 2004 | 01:54 PM
JDM PRO's Avatar
no hole cut outs on the corners...2 pre-drilled holes for the screws. Not sure if that helps but i could take pix later
Old Oct 16, 2004 | 02:06 PM
OneFire's Avatar
Default Re: how do i know if mugen lip is real? (JDM PRO)
fitment? I don't know I can usually tell if the lip is fake or not just by comparing pictures of the real mugen lip and the fake mugen lip.
But I don't know who in the hell would remove a mugen badge from their mugen lip. Isn't that the whole purpose of buying the real deal? To show it off?
Old Oct 16, 2004 | 02:18 PM
Silver-Shooter's Avatar
the real lip is flush on the sides while the replicas flare out.
Old Oct 16, 2004 | 04:14 PM
kidkombo's Avatar
Default Re: (Silver-Shooter)
they are real when the mounting brackets are RIVETED to the lip WHICH IS MADE OF ABS PLASTIC, not fiberglass.....the holes on the right and left sides arent actually holes..they are filled in..and there is are black stickers that come with the lip in order to fill it...making it look like it has holes..or ducts on either side...plus the fitment is tight..but perfect...the holes are all predrilled for you..making it like mounting a stock si lip, the hardware is all oem too.....oh yeah this is for ek...
if you have any other questions other than that...prolly means you got a fake one... jk
Old Oct 16, 2004 | 04:26 PM
WhoisDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">no hole cut outs on the corners...2 pre-drilled holes for the screws. Not sure if that helps but i could take pix later</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo &raquo;</TD></TR><TR><TD CLASS="quote">they are real when the mounting brackets are RIVETED to the lip WHICH IS MADE OF ABS PLASTIC, not fiberglass.....the holes on the right and left sides arent actually holes..they are filled in..and there is are black stickers that come with the lip in order to fill it...making it look like it has holes..or ducts on either side...plus the fitment is tight..but perfect...the holes are all predrilled for you..making it like mounting a stock si lip, the hardware is all oem too.....oh yeah this is for ek...
if you have any other questions other than that...prolly means you got a fake one... jk</TD></TR></TABLE>
Old Oct 16, 2004 | 05:14 PM
Airbag Club's Avatar
Default Re: how do i know if mugen lip is real? (whoisdan)
correct, real one has a bunch of mounting brackets on the bottom, and fitment is like OEM. the holes on the side are also blocked in with a black sticker that goes in it. it also has two holes for the mugen badge to be rivetted in.. the material is very hard, and you can tell the difference between a real and a fake mugen lip...
here are some pictures...don't mind the rock chips, it's a daily driver..
blocked holes with stickers..
rivetted mugen badge..
JDMTyler3326
Sep 5, 2009 03:31 PM
spintboy
19
Apr 9, 2008 06:08 AM
mike93eh
12
Jan 30, 2004 08:47 PM
rocco
35
Feb 5, 2003 09:49 PM
