mugen mf10 offset 50+?
Old Oct 16, 2004 | 11:52 AM
adddddaaammmm's Avatar
Default mugen mf10 offset 50+?
hey guys i was wondering if that offset would be okay for my R. if not what is the best offset running stock calipers. thanks guys
Old Oct 16, 2004 | 11:58 AM
Curt941's Avatar
Default Re: mugen mf10 offset 50+? (adddddaaammmm)
Well, the stock offset is +50, but stock wheels are 6" wide...thus the mf10's will stick out an extra half inch...but it won't be noticeable. Mugen designed them wtih +50 offset for a reason
Old Oct 16, 2004 | 12:33 PM
George Knighton's Avatar
H-T Order of Merit
The OEM Honda Integra wheels are +50 even in the 16x7 size, and we know that works OK with 215-45-16.
The Spoon 16x7 are +45, and IMHO that looks a little teeny bit better and is a good idea if you're using Azenis or R comps.
The popular offset these days for 15x7 seems to be +38 or +40, but many of us end up rolling the rear for clearance with wide tyres.
Old Oct 16, 2004 | 05:28 PM
KOALA YUMMIES's Avatar
Default Re: mugen mf10 offset 50+? (Curt941)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 &raquo;</TD></TR><TR><TD CLASS="quote">Well, the stock offset is +50, but stock wheels are 6" wide...thus the mf10's will stick out an extra half inch...but it won't be noticeable. Mugen designed them wtih +50 offset for a reason </TD></TR></TABLE>
Wrong the wheels wont stick out a half inch, the offset is the only thing that determines how much it sticks out. A 15x6 and 15x7 both at +50 will both stick out the same ammount.
"The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel." http://www.tirerack.com/wheels/tech/offset.htm
Old Oct 16, 2004 | 05:48 PM
uNF$@#!'s Avatar
Default Re: mugen mf10 offset 50+? (KOALA YUMMIES)
you just contradicted yourself dude.
you said yourself, the offset determines how far out your wheel sticks out.
given a wider wheel, its feasible that the wheel will stick out more depending on which side of the wheel the extra 1" is thrown on.
Old Oct 16, 2004 | 06:04 PM
Curt941's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks man, that graphic proves my point. there is a 1" difference between a 6" wheel and a 7" wheel...i assume you could figure that out. Half of 1" is 1/2"...thus on either side of the centerline of the wheel will be an extra 1/2"...the offset as you quoted is the distance from the mounting hub surface to the centerline...thust if they have the same offset but there is an extra 1/2" of wheel on either side of the centerline they will stick out AND in an extra 1/2"....
pwned by your own diagram
Old Oct 16, 2004 | 06:26 PM
pwned by your own diagram </TD></TR></TABLE>
Yeah whatever.
Old Oct 17, 2004 | 11:32 AM
thanks guys
Old Oct 17, 2004 | 11:58 AM
Curt941's Avatar
you're welcome.
Old Oct 17, 2004 | 11:59 AM
Curt941's Avatar
Hey man, no hard feelings...I had a KOALA in my Calc class in college and he wasn't very good at math either
KRWOO79
Acura TSX
Jun 13, 2005 08:44 AM
RhdRicheeee
Mar 8, 2005 01:12 AM
speedehatch
Sep 29, 2004 12:22 PM
Eric R
Nov 4, 2003 09:48 AM
All Motor TypeR 133
Feb 14, 2003 11:21 AM
