painting valve cover - paint temp question
I got textured black wrinkle paint. On the back it lists valve covers as an application for the paint, but it does not mention withstanding high temperatures. How hot does the valve cover typically get, and do you think this paint will work?
one time i touched a valve cover after running my engine and it burnt me. I went "ouch" and went home to cry to mommy.
But seriously if it lists it as an application then it must work I couldn't imagine your engine making enough heat to burn that crap.
[Modified by 94IntegraGSR-OVR, 8:50 AM 12/18/2001]
It should work fine, the wrinkle finish I had was specifily for car stuff, so if its that kind then you are ok, if its not then you are most likely fucked.
[Modified by 97blackteg, 3:56 AM 12/23/2001]
You dont need temperature paint for the valve cover......I used regular paint looks good. I dont know about that wrinkle paint if it looks good or lasts
SmokyMtnRex
Mar 23, 2002 09:21 AM
