Ran at track lastnight. Ls/Vtec
Old Oct 16, 2004 | 07:24 AM
tnsxsear1's Avatar
Default Ran at track lastnight. Ls/Vtec
Well after getting my car tuned "just fuel and ignition" from "fuccarlos" I ran at a local track lastnight. Stock b18b1 Block with Alaniz head, skunk2 stg2cams, DTR header on some 22" m&h's. I managed to get a 13.70@95.9 with a 1.8 6oft. Keep in mind that im in El Paso,TX which is about 4000 ft above sea level. What do you all think I should do to get a faster time. I just ordered a headlight ram air kit. I was thinking maybe some skunk2 drag launch springs and some traction bars. Cuz i kept spinning off the line at 11lbs psi. -Paul
Old Oct 16, 2004 | 07:38 AM
90 integra's Avatar
nice time for a stock block.youll need some traction bars and better motor mounts.get the block built and youll be in the 12s.
Old Oct 16, 2004 | 09:17 AM
tnsxsear1's Avatar
Default Re: (90 integra)
yeah my top mount is torn to **** but i have a placeracing rear mount.
Old Oct 16, 2004 | 10:04 AM
GOLDBERG's Avatar
Default Re: (tnsxsear1)
yeah,...build the bottom
Old Oct 16, 2004 | 10:11 AM
The Destroyer's Avatar
Default Re: (GOLDBERG)
Report back once you get the traction bars and launch springs.
Old Oct 16, 2004 | 10:20 AM
JL's Avatar
JL
Default Re: Ran at track lastnight. Ls/Vtec (tnsxsear1)
95.9
Old Oct 16, 2004 | 02:37 PM
DefiantGSR's Avatar
what car is the motor in? lb?
Old Oct 16, 2004 | 04:01 PM
prestonpark's Avatar
u need more power look at ur mph
howmuch power u put at the wheel
or do soem serous weight reduction
Old Oct 16, 2004 | 05:24 PM
tnsxsear1's Avatar
Default Re: Ran at track lastnight. Ls/Vtec (civic2003)
the motor is in a 95 civic vx hatch. I have yet to dyno it but hope to do so within a few weeks.
Old Oct 16, 2004 | 06:46 PM
UncleD's Avatar
I don't understand how you can run these cams with that compression unless the head has been milled some. Sk2 stage 2's are fairly aggresive, if I'm not mistaken you're runnin MAYBE a 9:5-10:1 compression......what head are you using(gsr/b16?) And that sea level baffles me.......hmmmmmm. If true, MUCH props, you have a quick car.
Old Oct 17, 2004 | 06:13 AM
tnsxsear1's Avatar
Default Re: Ran at track lastnight. Ls/Vtec (clean rice)
Yeah let me clarify. Its a stock honda parts block. It has JDM p30 pistons which are still smaller than CTR's and all of Joes heads from alaniz are milled about 30 thousandths. So it sits right under 12:1
Old Oct 17, 2004 | 06:36 AM
91civicDXdude's Avatar
fill your mounts with poly glue
Old Oct 17, 2004 | 06:39 AM
HONDABROMANDUDE's Avatar
How much power did you put down?
Old Oct 17, 2004 | 05:35 PM
kyosoeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 &raquo;</TD></TR><TR><TD CLASS="quote"> im in El Paso,TX which is about 4000 ft above sea level. </TD></TR></TABLE>
i can vouch for this. i live here too and our times do suck compared to the rest of the country. stock s2k's only run a 15.0-14.8 at best and stock z06 vette's run about 13.0 on stock rubber
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 &raquo;</TD></TR><TR><TD CLASS="quote"> i kept spinning off the line at 11lbs psi. -Paul</TD></TR></TABLE>
a 1.8 60ft means your not spinning off the line. but good times
Old Oct 17, 2004 | 05:46 PM
EdBoon's Avatar
That's pretty good. At sea level...you should see at least half a second off ur time.
Old Oct 17, 2004 | 05:49 PM
Default Re: Ran at track lastnight. Ls/Vtec (kyosoeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyosoeg6 &raquo;</TD></TR><TR><TD CLASS="quote">
i can vouch for this. i live here too and our times do suck compared to the rest of the country. : </TD></TR></TABLE>Try going fast in Denver
Old Oct 31, 2004 | 06:29 PM
tnsxsear1's Avatar
Default Re: Ran at track lastnight. Ls/Vtec (HONDABROMANDUDE)
Ran Again tonight open header and hit my best of 13.4@100.6 1.86 60ft
Old Oct 31, 2004 | 08:25 PM
Red D Dragon's Avatar
not bad.. i hit 13.8 @100.65 with a stock gsr motor and 2.19 60 foot.. but i'm sure the elevation kills you
Old Oct 31, 2004 | 08:57 PM
UnKnownUser's Avatar
Default Re: (Red D Dragon)
Not to bad...But bro not smart puting your adress in your sig say bye bye to lsvtec!
Old Oct 31, 2004 | 10:52 PM
G U E C O's Avatar
nice reaction time. and what he said ^
Old Nov 8, 2004 | 11:36 AM
specie's Avatar
Default Re: (LSVTEC_DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Not to bad...But bro not smart puting your adress in your sig say bye bye to lsvtec!</TD></TR></TABLE>
Yup.
Old Nov 8, 2004 | 07:55 PM
ceLtic's Avatar
N/A wh0re!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 &raquo;</TD></TR><TR><TD CLASS="quote">the motor is in a 95 civic vx hatch. I have yet to dyno it but hope to do so within a few weeks.</TD></TR></TABLE>
uhhh....
13.42@100.6 AllMotor Ls/Vtec
Need a place to stay when in FL?
Visit Me. My mom makes good food!
Kinh Huynh
4795 54th Ave N
St. Petersburg, FL 33714
United States
and yeah the car is in the back, and the keys are in the flower pot.
Old Nov 8, 2004 | 08:21 PM
TURBOFTW's Avatar
Default Re: Ran at track lastnight. Ls/Vtec (ceLtic)
well he did say he lived in texas and thats a florida address maybe thats a scammer or something?
93H22ACX
Nov 1, 2004 03:25 AM
streetlvlhatch
Apr 23, 2004 07:29 AM
SpoolnG2
Apr 25, 2003 09:24 AM
SpoolnG2
Apr 24, 2003 09:09 PM
SpoolnG2
Apr 23, 2003 10:17 PM
