Which setting more power in dyno??
Old Oct 16, 2004 | 03:12 AM
Edw-R's Avatar
Default Which setting more power in dyno??
15" factory wheel with semi-racing tyres (195/55/15) Total= 14kg or
16" Aftermarket wheel with street tyres (205/45/16) Total= 19kg
Hope can hear your opinion!!
Old Oct 16, 2004 | 03:15 AM
Smeeg Heed's Avatar
Default Re: Which setting more power in dyno?? (Edw-R)
1. It's going to make almost no difference.
2. I think it's obvious just by reading what you stated that the slight difference you do see would be less power with the larger wheels. Why was it even necessary to ask this question?
Old Oct 16, 2004 | 08:51 AM
Chris F's Avatar
Default Re: Which setting more power in dyno?? (Smeeg Heed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smeeg Heed &raquo;</TD></TR><TR><TD CLASS="quote">1. It's going to make almost no difference.
2. I think it's obvious just by reading what you stated that the slight difference you do see would be less power with the larger wheels. Why was it even necessary to ask this question?</TD></TR></TABLE>
Yeah, of course it's going to be less power on a , and probably measurable. 3-4 HP maybe.
Taller wheels usually means higher moment of inertia, even if the weights were the same. Like when a figure skater spins slowly with her arms out, and then spins faster with her arms pulled in. Even with the same weight, her moment of inertia was lower with her arms pulled closer to the axis of her rotation.
-Chris
Old Oct 16, 2004 | 09:13 AM
Bbasso's Avatar
Is this a trick question?
Your motor will still make the same power if you had 20inch bling or 15inch- 8lbs wheels.
Now as for what take less strain to get the power to the ground... just use your head
Modified by Bbasso at 6:11 PM 10/16/2004
Old Oct 16, 2004 | 09:32 AM
Rory Breaker's Avatar
Default Re: Which setting more power in dyno?? (Bbasso)
It isnt a trick question, there will be a difference if hes on rollers (obviously a dynapak wouldnt make a difference). I wouldnt say much though in your case...a few whp if that.
Now, 20's on the other hand...
Old Oct 17, 2004 | 12:36 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Is this a trick question?
Well, it's not a well worded question... But I'm sure he meant :
"Which set of wheels will allow me to measure more power from my car on a chassis dynamometer, such as Dynojet? If I had paid attention in high school physics, I wouldn't have had to ask. If I had paid attention in English class, I might have put together a single complete sentence in my post."
Sorry if English is your 2nd language.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edw-R &raquo;</TD></TR><TR><TD CLASS="quote">Which setting more power in dyno??
Old Oct 17, 2004 | 03:35 PM
Bbasso's Avatar
Default Re: Which setting more power in dyno?? (ccfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">Well, it's not a well worded question... But I'm sure he meant :
I only take things on the WWW at face value, its rather hard to read between the lines Unless I know the person.
civic eg
13
Jan 7, 2007 08:35 PM
euG3dc2r
Oct 29, 2004 08:21 AM
blackriceman
May 20, 2004 10:25 PM
Eg692Si
Aug 31, 2003 10:16 PM
ej20_chris
Dec 23, 2001 12:02 PM
