got some maxspeed coilcovers, camber problem?
Hey guys, I just got a set of 4 maxpeed coil covers for my 93 LS. I've only got 15 inch rims on her right now and I was wondering if I go 2.25 in the front and 2 in the back if i'll need a camber kit or not. I want to go pretty low but if I need a camber kit I as just gonna throw it on when I put the maxspeeds in. Lemme know what you think. Oh yeah and what camber kit should I be lookin at too. Thanks
if you drop it over 1.5" id get the kit else all your extra money is going to be buying new tires due to the camber wear. go for subtle drop until you get the cash for the camber kit if you cant afford it right off.
i have a full ingalls kit i bought from hondaintegrals2@aol.com aka manchester honda. he always has deals on http://www.groupbuycenter.com for the kits. expect to pay another $200-$220 for the ingalls kit.
camber kit is definitely the way to go if you want to keep your tires in good shape.......i got the ingalls kit for 145.....real easy to install...........
hey is it necessary to do both the front and rear camber kits?? Just wonderin if I need the full or not. Thanks again.
you have the same drop as me and you will need a camber kit in the front but for the back you can just use washers, on superhonda there is step by step instructions with pics its easy, i got the ingalls kit, make sure you get the rubber kit for a quiet ride
