ls block with ctr pistons (what horsepower? Times? )
Im building an ls block with ctr pistons. I know this raises the crompesion quite a bit. The head will be ported and polished (stock valves) with crower 405 cams (the ones that dont require rocker mods) to a dual mikunni 45 carb setup. I know the carbs are different but what kind of horsepower and times have people done with this setup(on fuel injection). I am stuck on not using v-tech so what are my options as far as heads go? does anyone know how to eliminate vtech (like ericks racing did in their 87 crx)?
If i cant figure out how to do that i will oversize the valves on the b18b head and use nitrous. This is a temporary bottem end that i want to play around with until mine is built. Any help would be apreciated
ya but the overall length might be different between the heads i wouldnt know and the compression difference between the 2 heads are way different the ls head is bout 11.6 then the gsr head is about 12.6 maybe more. so u have to think about that
Well im sorry im jumping way ahead of myself. This is just a play motor straight ls block and head. Im building a different ls block that will be my quote unquote race block. that will have less compression and use heavy doses of nitrous. On that block i was considering eliminating vtec like aguilar did to save some ratating mass. i dont know im just throwing ideas around
volcom40street
17
Jan 2, 2005 02:10 PM
Civic
20
Oct 29, 2003 06:02 PM
