The $50 "Magic" intake
Old Dec 17, 2001 | 10:48 AM
HX_Guy's Avatar
Default The $50 "Magic" intake
+16 WHP and +17 FT-LBS TORQUE at 4800 RPMs from a $50 cold air extension...now who wants to aregue that isnt a deal?
The intake tube is 38" long (from TB to filter - not including filter itself) and 3" in diameter using a generic $20 cone filter. The first part of the intak is a DC D.A.C. and the extension is made by Injen.
The runs were done back to back maybe 3-4 minutes apart, one with the extension on..the other with it off.
Old Dec 17, 2001 | 11:00 AM
sgT's Avatar
sgT
Default Re: The $50 "Magic" intake (HX_Guy)
That is A LOT of torque....
Old Dec 17, 2001 | 11:18 AM
fastbrakes's Avatar
Looks like a classic example of ram air induction tuning designed for a specific RPM. If you experiment with different lengths you can tune that sweet spot to whatever RPM you want....
Old Dec 17, 2001 | 11:20 AM
HX_Guy's Avatar
Default Re: The $50 "Magic" intake (fastbrakes)
Yea the problem is I dont really have much space to add more piping. It would be nice to get that "hump" in the area of 6000-7500 or higher.
Old Dec 17, 2001 | 11:23 AM
Type R's Avatar
what was the name of the filter you used?
Old Dec 17, 2001 | 11:24 AM
HX_Guy's Avatar
Default Re: The $50 "Magic" intake (Type R)
Seriously, I dont dont. Jus ta Generic one...like Revmax or some crap.
Old Dec 17, 2001 | 11:28 AM
sgT's Avatar
sgT
So is this longer or shorter than an AEM??
Old Dec 17, 2001 | 11:29 AM
HX_Guy's Avatar
Default Re: The $50 "Magic" intake (sgT)
I really dont know..I would say probably about teh same size. Someone should go measure their ITR AEM intake...theyre 3" in diameter as well right?
Old Dec 17, 2001 | 11:30 AM
sgT's Avatar
sgT
the ITR aem is 3"
Old Dec 17, 2001 | 11:34 AM
Mista Bone's Avatar
D Tranny Guru
Try going 2" shorter in steps, will have to dyno test to see how far the peak will move upward.
I "guess" about 3.5-4" shorter will raise sweet spot to about 5700-6000 rpm.
Only way to test is on the rollers.
Old Dec 17, 2001 | 11:38 AM
HX_Guy's Avatar
Default Re: The $50 "Magic" intake (Mista Bone)
Hmm..so shorter should move it up?
Im willing to try this out, but Ill have to wait until after the whole VTEC project..hopefully that wont get rid of the "hump".
Old Dec 17, 2001 | 11:42 AM
HX_Guy's Avatar
Im guessing the intake doesnt have to have bends in it to gove these results right?
My CAI Extension is 22" long..so if I ge ta 3"x22" straight pipe it should give the same results right?
Im thinking Ill buy a 26" pipe and dyno that..then start cutting it down by 2" each run. Once I get the results I want, Ill cut my CAI extension to that length.
Sound good?
Old Dec 17, 2001 | 10:49 PM
Mista Bone's Avatar
D Tranny Guru
For testing, the intake not need to go though fender or whatever. YOu can lay it across the front of car. Just make sure no fans are blowing on it.
Old Dec 17, 2001 | 11:28 PM
spiderman's Avatar
New User
Has anyone done more testing on this.
With various diameters and lengths.
Old Dec 17, 2001 | 11:57 PM
Ch33se's Avatar
New User
Default Re: The $50 "Magic" intake (spiderman)
i thinkyou are just wasting your time...im sure comptech, mugen, spoon, aem, injen, yadyadayada tried all this already dont you think?
Old Dec 19, 2001 | 07:33 AM
HX_Guy's Avatar
Default Re: The $50 "Magic" intake (caliItr)
i think you are just wasting your time...im sure comptech, mugen, spoon, aem, injen, yadyadayada tried all this already dont you think?
I might be...I not not be. The thing is...AEM, Comptech, etc make "generic" intakes to fit many applications. Im sure tehy havnt made one specifically for a B20 running 11.5:! compression with a Skunk2 intake manfiold and Crower cams....so my engine will react different then the Civic EX the intake was originally made for.
I already have the extra intake piping...an hour at the dyno will run me $75...so why the hell not try?
Old Jan 7, 2002 | 06:05 AM
spiderman's Avatar
New User
He HX_Guy did you do the dyno run jet???
Old Jan 7, 2002 | 06:06 AM
HX_Guy's Avatar
Huh?
Old Jan 7, 2002 | 06:09 AM
spiderman's Avatar
New User
I already have the extra intake piping...an hour at the dyno will run me $75...so why the hell not try? #####
Old Jan 7, 2002 | 06:16 AM
DutchITR1689's Avatar
Longer intake = more torque at low rpms
Shorter intake = more torque at high rpms
That's why the GSR has variable intake length....
Old Jan 7, 2002 | 06:17 AM
HX_Guy's Avatar
Default Re: The $50 "Magic" intake (EuroITR1689)
Well that may be true in some cases...but obviously it didnt hold water in my case. The shorter intake made LESS power EVERYWHERE.
Old Jan 7, 2002 | 06:18 AM
How about measurement errors (variations) ? You really need more runs to draw some conclusions....
Old Jan 7, 2002 | 06:20 AM
HX_Guy's Avatar
What do you mean by measurment errors? As in....?
Old Jan 7, 2002 | 06:22 AM
Measurement errors of the Dynojet.
And what was the short intake? Same diameter? Same filter? Resonance box removed? Was it exactly the same intake tube + filter but than shorter?
[Modified by EuroITR1689, 4:24 PM 1/7/2002]
Old Jan 7, 2002 | 06:24 AM
spiderman's Avatar
New User
The dyno has a tolerance in measuring BHP (somethink like 5%)
