T3/T67 spool..what RPM
Old Oct 15, 2004 | 07:53 PM
B20luda's Avatar
Default T3/T67 spool..what RPM
i have a b20a old prelude motor simular to the b20b ...9:1 ported head 2.5in DP 3in ex. no cat...i will be runnin around 10-12psi ...just wonder what RPM this baby will spool....63AR turbine ...67trim compressor...before i had a 59trim compressor and it spooled around 3600-3700rpm...what do u guys think...thanks...
Old Oct 17, 2004 | 10:02 AM
B20luda's Avatar
Default Re: T3/T67 spool..what RPM (B20luda)
now one has any experience with this...come on...
Old Oct 17, 2004 | 10:06 AM
done's Avatar
my 67 would come on around 3500rpms..
5psi by 3500rpms
Old Oct 17, 2004 | 10:22 AM
B20luda's Avatar
Default Re: T3/T67 spool..what RPM (Jordo)
sweet what was your setup...how long until full boost...
Old Oct 17, 2004 | 11:11 AM
BoostR41's Avatar
I have been hearing sc61's don't spool till 5k how does a t3/t67 spool at 3500
Old Oct 17, 2004 | 11:52 AM
b16sedan's Avatar
Default Re: T3/T67 spool..what RPM (BoostR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">I have been hearing sc61's don't spool till 5k how does a t3/t67 spool at 3500</TD></TR></TABLE>
That's what we like to call a typo. Figure 4500-5000, not 3500.
If you have a 67 trim wheel that does not make it a T67. The T67/TO4R compressor wheel is 63 trim, not 67 trim. Clarify what turbo you have a little better.
Old Oct 17, 2004 | 12:35 PM
B20luda's Avatar
Default Re: T3/T67 spool..what RPM (b16coupe)
well the wheel is 67mm in diameter not sure what trim it is?
Old Oct 17, 2004 | 12:50 PM
alpha's Avatar
Till? Are you saying you have been hearing SC61's dont make ANY boost until 5,000RPM? If so you have been hearing wrong.
Old Oct 17, 2004 | 01:05 PM
SiRkid's Avatar
Default Re: T3/T67 spool..what RPM (0x64)
i think jordo means its making some boost by 3500 rpm...5psi is bullshit though imo.
maybe a couple of psi ..then building to full boost by 5500-6k ish.
Old Oct 17, 2004 | 01:19 PM
Boltz's Avatar
Default Re: T3/T67 spool..what RPM (SiRkid)
if jordo got on it at about 2500 in fifth gear I wouldnt be that suprised it if spooled a few pounds by 3500, it will never hit that in first or second gear
Old Oct 17, 2004 | 04:53 PM
done's Avatar
Default Re: T3/T67 spool..what RPM (Boltz)
dude i **** you not, i would get about 5psi in like 3rd gear around 3500rpms, then full boost by 4k..
i only had the car running like that for 2 days though
Old Oct 17, 2004 | 05:08 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">dude i **** you not, i would get about 5psi in like 3rd gear around 3500rpms, then full boost by 4k..
i only had the car running like that for 2 days though </TD></TR></TABLE>
8.7lbs around 4,000RPM with your B18c5 correct?
Old Oct 17, 2004 | 05:17 PM
FOrSfEd's Avatar
I get 5 psi by around 4200, though my car is untuned and I have yet to really get on it so it should be a lil faster.
Old Oct 17, 2004 | 05:45 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">
8.7lbs around 4,000RPM with your B18c5 correct?</TD></TR></TABLE>
i only was boosting 7psi
Old Oct 17, 2004 | 05:56 PM
JDMs1eeper's Avatar
I have a compressor 70 a/r and 84a/r hot side with a 64.5 trim ballbearing turbo and was at 10psi at 4k. gotta love BB turbos This was on my b20b4.
when getting on it at a roll it would boost pretty much instantly to full boost.
What kinda turbo is this?
Old Oct 18, 2004 | 08:41 AM
B20luda's Avatar
Default Re: T3/T67 spool..what RPM (JDM S1eeper)
its kinda a mix of things...it has a chrysler center section (T3) and i have a Volvo turbine housing..&gt;63Ar and i just got parts from turbonetics...67mm compressor wheel and i think 63 trim .70ar...
Old Oct 18, 2004 | 09:00 AM
Sonny's Avatar
Jordo and ForSfed: What a/r turbine housing are you using? Are you guys running T3 turbine housings and wheels or T4 stuff?
Sonny
Old Oct 18, 2004 | 09:01 AM
Chip's Avatar
Default Re: T3/T67 spool..what RPM (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">Jordo and ForSfed: What a/r turbine housing are you using? Are you guys running T3 turbine housings and wheels or T4 stuff?
Sonny</TD></TR></TABLE>
T3/T67, to me, usually means they're running a T3 exhaust housing Having driven a straight PT67 P-trim setup, I can say that there is no chance of a PT67 making 7 pounds of boost at 3500, or 4000.
Old Oct 18, 2004 | 09:04 AM
FOrSfEd's Avatar
Default Re: T3/T67 spool..what RPM (Chip)
I'm running a t3, .63 a/r
Old Oct 18, 2004 | 09:14 AM
M.A.R.C.'s Avatar
Till? Are you saying you have been hearing SC61's dont make ANY boost until 5,000RPM? If so you have been hearing wrong.</TD></TR></TABLE>
you haven't seen the one that was on my D16 then
Old Oct 18, 2004 | 02:41 PM
alpha's Avatar
Default Re: T3/T67 spool..what RPM (CivicRyda2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">
you haven't seen the one that was on my D16 then </TD></TR></TABLE>
To be honest I have yet to see one in person on a D16.
Old Oct 18, 2004 | 04:04 PM
PM-Performance's Avatar
no way on the 3500 rpm thing. i had one and mine was 2.0, yes it spooled nicely, but not that nicely.
Old Oct 18, 2004 | 04:18 PM
BoostR41's Avatar
Default Re: T3/T67 spool..what RPM (itr206)
I would really like to see a map that shows how this turbo is effiecient. the T3 wheel speed would be insane with the compressor pushing anything higher than about 8psi or so
Old Oct 18, 2004 | 04:23 PM
Sonny's Avatar
Default Re: T3/T67 spool..what RPM (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a t3, .63 a/r</TD></TR></TABLE>
Thanks, man. I'm really wanting to run the T3/T67 on my RX-7. I think a .63 a/r turbine housing with a stage 3 wheel would spool up early enough to make it flexible enough for the street.
Sonny
Old Oct 18, 2004 | 08:19 PM
M.A.R.C.'s Avatar
To be honest I have yet to see one in person on a D16.</TD></TR></TABLE>
yah it's not a bad choice for a fully built d16... as long as u have a 3" downpipe... my 2.5" kiiiiilled me. i got full boost @ 5000-5500 rpm but i was spinning it to 8000-8500
