need help changing brakes on 2000 accord
Old Oct 15, 2004 | 05:03 PM
milano2kdc2's Avatar
Default need help changing brakes on 2000 accord
okay so im a little stuck right now.. how do you get the caliper on the rear brake of a 2000 accord to flip up so that i can change the brake pads..
please help i need to get this done asap
Old Oct 15, 2004 | 05:51 PM
t0p_sh0tta's Avatar
Default Re: need help changing brakes on 2000 accord (milano2kdc2)
There should be two bolts that hold the caliper to the bracket. Remove either the upper or the lower bolt and the caliper should pivot. I don't have any 1st hand experience with the Accord but the bolts are usually 14mm or larger (FYI they were 17mm on my maxima).
Old Oct 16, 2004 | 07:44 PM
PrettyLude's Avatar
they are some 14mm, and you can use a big screwdriver to turn the pistons in the calipers in
ryerye411
Jul 21, 2009 10:01 AM
irishdub22
Nov 18, 2007 10:33 AM
milano2kdc2
Oct 15, 2004 05:59 PM
aznchino16
Aug 19, 2003 06:22 PM
