want to turbo a d16 head on z6 block what pistons?
Old Oct 15, 2004 | 12:57 PM
mrmechanic's Avatar
Default want to turbo a d16 head on z6 block what pistons?
Well I have read all the posts on here concerning the backward approach of putting an a6 head on a z6 block. I know its gonna suck on compression, but what kind of pistons should i get, since i am going to turbo it? SRP has got some z6 pistons rated at 9:1 and some for 10:1, should i got for the 10:1 to help make up for the bigger chamber? And, since i got everything apart, should i go ahead and get the head ported and polished? I was also thinking about getting the head milled, i think is what it's called. Thoughts on this please.
Old Oct 15, 2004 | 01:29 PM
nonvtecD's Avatar
Check the compression calculator to see what the compression will be. Why would you do this? You have a Z6 block but no head?
Old Oct 15, 2004 | 02:10 PM
mrmechanic's Avatar
Default Re: (D15B7turbo)
i had the a6 head already, and the guy i bought the z6 block from said it would all bolt up fine, compression calculator says around 9.7:1 compression with the higher compression pistons.
Old Oct 15, 2004 | 03:16 PM
Bserieskllr's Avatar
ive heard a6 block is stronger cause of steele main caps or something ill look up on it too see if im right.
Old Oct 15, 2004 | 05:16 PM
djwest24's Avatar
Default Re: (Bserieskllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">ive heard a6 block is stronger cause of steele main caps or something ill look up on it too see if im right.</TD></TR></TABLE>
ur right, but not all of them, only a lucky few.
mike93eh2
Feb 11, 2009 08:09 PM
B-B-K
Apr 5, 2004 07:21 PM
Toptul_Honda
Nov 13, 2003 08:59 PM
