Timing Belt Q
Old Oct 15, 2004 | 12:49 PM
Methane2k2's Avatar
Default Timing Belt Q
Does anyone know at what mileage is recommended to change a cars timing belt?
And also does anybody know how much is it including paying someone to put it on?
like about how much the prises are?
Methane2k2's Avatar
Default Re: Timing Belt Q (Db2_iNtEgRa)
i got a DA with 93K miles on it i think its time for me to change it... but am not sure
Old Oct 15, 2004 | 12:50 PM
iixerOii's Avatar
Usually every 90k is the suggested I believe and timing belt change runs from 600$+ I think.
Old Oct 15, 2004 | 12:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Timing Belt Q (iixerOii)
It should be around $400-$500... more if you also get the water pump replaced (more parts and more labor).
I have seen some places run specials to change the timing belt for under $400.
Old Oct 15, 2004 | 12:53 PM
njandrewg's Avatar
Default Re: Timing Belt Q (PatrickGSR94)
how hard would it be to change a timing belt yourself..and are there any walk throughs for that?
Old Oct 15, 2004 | 12:56 PM
iixerOii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">It should be around $400-$500... more if you also get the water pump replaced (more parts and more labor).
I have seen some places run specials to change the timing belt for under $400.</TD></TR></TABLE>
400$!? I need to find these speicals
Old Oct 15, 2004 | 12:57 PM
iixerOii's Avatar
Default Re: Timing Belt Q (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">how hard would it be to change a timing belt yourself..and are there any walk throughs for that?</TD></TR></TABLE>
http://www.c-speedracing.com/h...t.php
B18C DIY timing belt change
Old Oct 15, 2004 | 01:47 PM
W.O.P.'s Avatar
$400???!!!! down in orem theres a place that does it for $150
Old Oct 15, 2004 | 02:22 PM
-DKap-'s Avatar
Default Re: Timing Belt Q (1quickLS)
400 usually includes all 90 k maintaince... 150-200 just for a timein belt replacement
Old Oct 15, 2004 | 02:45 PM
dom93hatch's Avatar
What if I have the parts (t belt, water pump, etc) ready? Will they do the job for cheaper? I honestly CANNOT find a damn crank bolt wrench so I can change my belt.
Old Oct 15, 2004 | 04:12 PM
r0nr0n's Avatar
Default Re: (dom93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom93hatch &raquo;</TD></TR><TR><TD CLASS="quote">What if I have the parts (t belt, water pump, etc) ready? Will they do the job for cheaper? I honestly CANNOT find a damn crank bolt wrench so I can change my belt.</TD></TR></TABLE>
what is a crank bolt wrench????
use a impact gun an the shortest socket that will fit (shorter has more torque )
at my shop we usally do a timing belts for $300 to $450
we always put new aux belts,water pump,timimg belt
Old Oct 15, 2004 | 05:07 PM
dc5r2002's Avatar
Default Re: (r0nr0n)
its 60k on a gsr
its 80k in the ls
Old Oct 15, 2004 | 06:39 PM
boosted k20's Avatar
Default Re: (Pulp Fiction)
damn 60K on a GSR??? where'd u get that info from? every 90-100K sounds right to me.
the hardest part about change n the timing belt is removing that crank pulley bolt. if u dont have an impact gun then it's gonna be pretty hard. u need to find a way to hold the crank pulley in place in order to loosen the bolt with a breaker bar. they make a tool that fits inside the crank pulley so that u can hold it in place. people also use this tool (dont know what it's called) that looks like a vice grip but has a chain that u wrap around the pulley to hold it in place.
Old Oct 15, 2004 | 06:43 PM
sibanez's Avatar
The first timing belt change on my Integra costed me nearly 7 bills at an Acura dealership around New Orleans, but I have learned. This did include all the other belts and water pump, but after doing it myself, I will never pay out like that.
For the cost of a decent electric impact and all of the parts, you can do it for $350ish and learn a lot about your car. If you ever plan to do any sort of upgrades to the motor (cams and such) it's not a bad thing to do. Of course, it's one of those things that if you screw up, it can cause some serious issues.
ezol
Acura TL, RL & ZDX
11
Sep 21, 2010 08:29 AM
chahsiubow
Dec 14, 2007 10:01 PM
BlackGser
Apr 27, 2005 11:00 AM
2camsaam
Jul 30, 2003 12:20 PM
