Cam Gears
I know theres a lot of different cam gears out there! I'm looking for one to put together with some M22s from Rocket motorsports. I need a good cam gear thats easy to adjust. Any help on my cam decision is great!
The only one's I ever recommend are ST Corsa. You'll undoubtedly hear countless other suggestions, but ST Corsa is the only one to feature a unique (and in my opinion far superior) design.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">The only one's I ever recommend are ST Corsa. You'll undoubtedly hear countless other suggestions, but ST Corsa is the only one to feature a unique (and in my opinion far superior) design. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99b18 »</TD></TR><TR><TD CLASS="quote">the tuner i go to says to go with skunk2. he said the others hes seen have a tendency to slip sometimes.</TD></TR></TABLE>
This is exactly the reason why I recommend ST Corsa. Because all the other brands use the same fundamental design as one another, they all have the potential to slip, but due to the ST Corsa's unique design they physically <u>can't</u> slip.
This is exactly the reason why I recommend ST Corsa. Because all the other brands use the same fundamental design as one another, they all have the potential to slip, but due to the ST Corsa's unique design they physically <u>can't</u> slip. </TD></TR></TABLE>
you got a website where i could take a look at these things?? im curious to see the design
The server appears to be down at the moment, but the company site is: STCorsa.com
Edit: Server's up.
Modified by Padawan at 1:17 PM 10/20/2004
Edit: Server's up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">The server appears to be down at the moment, but the company site is: STCorsa.com </TD></TR></TABLE>
those definately look like the best ive seen on the market.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">Never had a problem with my STR's.
its funny, most people say the AEM ones are no good, but I have a friend pushing over 400whp and he uses AEM ones
</TD></TR></TABLE>its funny, most people say the AEM ones are no good, but I have a friend pushing over 400whp and he uses AEM ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic »</TD></TR><TR><TD CLASS="quote">
its funny, most people say the AEM ones are no good, but I have a friend pushing over 400whp and he uses AEM ones</TD></TR></TABLE>
go figure right?
go figure right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic »</TD></TR><TR><TD CLASS="quote">its funny, most people say the AEM ones are no good, but I have a friend pushing over 400whp and he uses AEM ones</TD></TR></TABLE>
It's not a question of making power. Basically any adjustable cam gear on the market will allow you to achieve the same power results. Instead, one of the prime concerns is the gears slipping, which can transform a 400 whp motor into a very expensive lawn decoration in a matter of seconds.
I just updated the cam gear section on my site last night.
I have most cam gears included, but some are missing that I need to get info from like buddy club and a few others
http://www.honda-central.com/r.../page/
here is some info I wrote up about cam gears in general.
Number of Bolts
More Bolts the Better
Marks painted or machined
Definetly get laser etched or machined timing marks. If they are painted onto the cam gear surface, it is just a matter of time before the marks wear off and then you can tell where you are cam gears are set to.
Rough Weight (each)
Lighter the better. Most modern cam gears designs wont break because of advancements in stress testing the cam gears via a computer model.
Materials Used
6061 Billet Machined is Really good stuff. As long as its that or higher you are getting a cam gear that is machined from a good alloy.
Anodized Finish
Anodized finish will look the nicest and will also keep the finish for the longest. You dont want a painted finish. The adonized finish should last the life the of the cam gear.
Engineered Tooth Profile?
If the teeth arent engineered properly, then the timing belt and wear prematuraly which can lead to either the belt slipping a notch on the cam gear or it breaking completely. Both of those will result in the engine blowing up. Even though this point is rarely brought up, it makes a difference in the long run.
Easy to read timing marks?
On the JG cam gears, it was really difficult to read what timing marks. Most newer cam gears will have timing marks that are easy to read and therefore easy to set your cam gears properly for your engine. If you advance/retard your cam gear to much you can bend a valve and blow up your engine.
Bolt or Lock design
Lock/Pin design is the best in my opinion. But a properly designed bolt design will work really good. As I said earlier, more bolts the better. I would recomend getting a cam gear that uses 4 or more bolts.
Manufactured In
GO USA! Support our country and economy. There is nothing wrong with cam gears made in Asia. But generally speaking companys that produce parts in house (in the US) will be able to look over production of parts better and ensure you are getting the higher quality manufactured part. If its coming from Asia, the tolerances can (not always) be less accurate.
Number of Bolts
Rough Weight (each)
Materials Used
Anodized Finish
Bolt or Lock design
Manufactured In
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 »</TD></TR><TR><TD CLASS="quote">I just updated the cam gear section on my site last night.
Number of Bolts
Rough Weight (each)
Materials Used
Anodized Finish
Bolt or Lock design
Manufactured In
you're the man
Number of Bolts
Rough Weight (each)
Materials Used
Anodized Finish
Bolt or Lock design
Manufactured In
you're the man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx »</TD></TR><TR><TD CLASS="quote">i had experience with jg and the mark were to close together. there good, buts its hard to change it without squinting your eyes</TD></TR></TABLE>
You are absolutely right. I just picked them up and they are very hard to see.
I'm using the Buddy CLub cam gears because they were on special at JHPUSA a while back. The price was good.
My only complaint about them is that they don't have a TDC mark. The timing marks are easy to read though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">
But as for quality, I trust the AEM ones..
simple nad effective</TD></TR></TABLE>
The 3 bolt AEM gears are pretty much THE worst gears you can buy.
