Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What spring rates do you guys recommend for a 2000 Civic Si that is....
Old Dec 17, 2001 | 08:50 AM
CivicSiRacer's Avatar
Default What spring rates do you guys recommend for a 2000 Civic Si that is....
A daily driver and weekend autocrosser? Something liveable, not too harsh, but good performance wise.
Old Dec 17, 2001 | 09:03 AM
Geezer's Avatar
Default Re: What spring rates do you guys recommend for a 2000 Civic Si that is.... (CivicSiRacer)
I get along fine with 350F/400R. Car doesn't wallow, but Madame Geezer will still ride to work in it.
Old Dec 17, 2001 | 10:08 AM
Mike P.'s Avatar
25 Year Member
Default Re: What spring rates do you guys recommend for a 2000 Civic Si that is.... (Geezer)
I'll second that...that's probably the perfect setup for you. I run 380/450 and it's a little tiny bit uncomfortable for daily, but I'm happy to live with it. I may try some Bilsteins next time around to see if those will tame it a little more.
Old Dec 17, 2001 | 01:47 PM
gsober's Avatar
Default Re: What spring rates do you guys recommend for a 2000 Civic Si that is.... (YellowCorn)
350f/400r is the set up i have with koni shocks. the ride is stiff but not too bad. any stiffer would be a little much.
[Modified by gsober, 5:48 PM 12/17/2001]
Old Dec 17, 2001 | 02:35 PM
4doorH22's Avatar
I run 380/450 and it's a little tiny bit uncomfortable for daily...
And luckily Ms. Yellowcorn seems to tolerate it too.
jonGSR
Suspension & Brakes
Feb 26, 2014 07:00 AM
patrickstar
Suspension & Brakes
Jun 10, 2009 09:42 AM
hatchblack
Honda S2000
Feb 9, 2007 08:40 PM
SD_EM1
Aug 13, 2003 01:57 PM
delslow94
Feb 10, 2003 08:24 PM
