STOCK 98 ITR DYNO'ED TODAY.... HERE ARE THE NUMBERS
Old Oct 15, 2004 | 11:38 AM
mikestypeRR's Avatar
Default STOCK 98 ITR DYNO'ED TODAY.... HERE ARE THE NUMBERS
well guys today I went and had the completely stock 98 ITR dyno'ed today ..... all brand new, plugs, wires, rotor, timing belt, water pump.
I know stock numbers may varry from car to car ... let me know what you think
Old Oct 15, 2004 | 11:42 AM
davidnyc's Avatar
Default Re: STOCK 98 ITR DYNO'ED TODAY.... HERE ARE THE NUMBERS (mikestypeRR)
They say drivetrain losses are around 20%? So, I am guessing 195hp * .8 = 156hp. I guess your car is just normal?
Some info for ya:
http://www.sdsefi.com/techdyno.htm
http://www.dynamometer.fsnet.c...P.htm
Old Oct 15, 2004 | 11:51 AM
Haleiwa-Brando's Avatar
Default Re: STOCK 98 ITR DYNO'ED TODAY.... HERE ARE THE NUMBERS (davidnyc)
interesting. Mine pulled 161. I've seen as high as 164 for baseline pulls. How many miles on the engine?
cheezthis's Avatar
Dynos never read the same, even w/correction. Case in point, my GSR w/an intake actually put down more...but I don't believe it was more at all. Every dyno is different...check your compression, and if it's solid as well, you should be happy
The most important thing is the a/f ratio...and it looks good.
Old Oct 15, 2004 | 11:52 AM
Bbasso's Avatar
Looks like you have a normal ITR, good thing!
as for % loss... I did the math on my chart and if the motor actually puts out 195 at the crank its a 16% loss.
Old Oct 15, 2004 | 12:03 PM
1GreyTeg's Avatar
Looks reasonable for the temp.
What's the mileage?
Old Oct 15, 2004 | 12:26 PM
Default Re: STOCK 98 ITR DYNO'ED TODAY.... HERE ARE THE NUMBERS (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">interesting. Mine pulled 161. I've seen as high as 164 for baseline pulls. How many miles on the engine?</TD></TR></TABLE>
77k.. but yeah i guess from car to car each will have a small difference.
Old Oct 15, 2004 | 01:22 PM
Dougie Pants's Avatar
Default Re: (LAQUALO69)
I pulled 191 wbhp and 132 wbtq on a JDM 96' Spec ITR with I/H/E with the stock P73 ecu
Old Oct 15, 2004 | 03:04 PM
uNF$@#!'s Avatar
Default Re: (Dougie Pants)
and people here pull 275whp+ with just a turbo on stock. your point is?
Old Oct 15, 2004 | 03:08 PM
Bbasso's Avatar
Your Not stock, why are you bothering to post your car's #s ?????
Old Oct 15, 2004 | 03:10 PM
1GreyTeg's Avatar
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Your Not stock, why are you bothering to post your car's #s ?????</TD></TR></TABLE>
Cuz he likes to annoy, I mean try's to impress us.
Or maybe he just can't read to well.
Old Oct 15, 2004 | 03:13 PM
Opie's Avatar
Good numbers Mike, I pulled 171 with the AEM kazoo and the comptech 4-2-1
My new setup is gonna get dynoe'd next month
Bbasso's Avatar
Default Re: (1GreyTeg)
Anton, I'll be right back, let me check my supplies.
Old Oct 15, 2004 | 03:14 PM
Bbasso's Avatar
Oh yeah I have a squirt left.
Bbasso's Avatar
Old Oct 15, 2004 | 07:25 PM
bbqman's Avatar
I guess with 150K my R is getting old. After reading about brian F's car dynoing at 170whp ...stock, I was disappointed with my palty 154whp.
Old Oct 15, 2004 | 09:18 PM
dandc2's Avatar
Default Re: (bbqman)
mike you get it dynoed over at auto tuner?
Old Oct 15, 2004 | 11:36 PM
xprohx's Avatar
I think too much
Default Re: (dandc2)
after reading the articles it sounds like the dyno gives more of a rough estimate of your car's whp due to various factors. i guess its more for tunning the a/f and such. the caR looks healthy
edit: my gsr put down similar #'s w/ bolt ons
96ej8MR
Sep 15, 2010 07:56 PM
Mopedstud
Dec 22, 2009 04:25 PM
bbqman
Mar 20, 2005 05:09 AM
hybrid69
Feb 16, 2005 12:06 PM
94si94cx
Dec 25, 2004 02:18 AM
