Question about 96-2000 civic K members
Does anyone know if the k member (the peice in the rear towards the firewall that hold the rack and pinnon and lower control arms is different sizes between a manual rack or power)? I have a 2000si civic coupe and I wanted to know if there was one available that was smaller in size. Thanks guys...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Motorsports »</TD></TR><TR><TD CLASS="quote">Sent you a PM.</TD></TR></TABLE>
Just post up the info!
No, it's totally different. And i'm not 100% sure, but i don't think the manual to ps crossmembers will be much different at all. Maybe slightly different bolt patterns on the rack mounting if anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">No, it's totally different. And i'm not 100% sure, but i don't think the manual to ps crossmembers will be much different at all. Maybe slightly different bolt patterns on the rack mounting if anything.</TD></TR></TABLE>
Thanks Tony
Guess we will have to deal with the tight engine bay squeeze of the rear member in the car...
Thanks Tony
It is completly different in design but I believe the mounting points are the same.
I remember reading Hasport recommending swapping to 92-95 X member in the 96-00 chassis when using one of their K-series mount kits. The reason behind it was header clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious »</TD></TR><TR><TD CLASS="quote">It is completly different in design but I believe the mounting points are the same.
I remember reading Hasport recommending swapping to 92-95 X member in the 96-00 chassis when using one of their K-series mount kits. The reason behind it was header clearance. </TD></TR></TABLE>
See, if that is true it would work great for what we need it for...
It's already posted below, but it sounds like you want to use the EG crossmember. It bolts right up and is significantly more compact. To answer your first question, my car originally came with PS and I put a manual rack on it. Bolted right up.
Tyler
Tyler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H »</TD></TR><TR><TD CLASS="quote">It's already posted below, but it sounds like you want to use the EG crossmember. It bolts right up and is significantly more compact. To answer your first question, my car originally came with PS and I put a manual rack on it. Bolted right up.
Tyler</TD></TR></TABLE>
Do you know if you can retain the original ek power rack and just install the eg cross member? And did you use a manual rack from an eg or ek?
Thanks everyone for their inputs...lots of help
Modified by ninesecrx at 6:41 PM 9/29/2006
go to http://www.k20a.org will find everything you need
Earl, I have a K member out of a 93Si that needs one nut welded on.
If you swap a manual rack into a 92-95Si you will need the passenger side rack clamp of the manual rack.
If you put a k member from a Cx in a Si you cannot fully clamp the passenger side of the Power Steering rack to the Cx k member.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fabman »</TD></TR><TR><TD CLASS="quote">a arms the same??????</TD></TR></TABLE>
no
no
SB97civic
Mar 10, 2004 09:31 PM
