how to improve 60' times?
how can i improve 60' times i am running a jdm second gen b16 and 60' looks shity. I know that if i had a lsd tranny then it would help on the launches. well how can one improve those slips?
I agree with the others when they say practice, practice, practice! I own a B16A with CTRs puttin down 161Whp and 112Tq. I have a quaife LSD on Azenis tires and my best 60 foot is 2.3. I need to learn how to launch the car better, I should have a lot better 60s. I was lettin the clutch out at about 5 grand and no tire slip, just need to learn no to be a punk and let the clutch out faster and get on the gas faster.
Just need to learn different luanch points.
What ticks me off is my boy has a BONE stock B16 in his Rex and he pulls 2.2 60s with no LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-B-K »</TD></TR><TR><TD CLASS="quote">I agree with the others when they say practice, practice, practice! I own a B16A with CTRs puttin down 161Whp and 112Tq. I have a quaife LSD on Azenis tires and my best 60 foot is 2.3. I need to learn how to launch the car better, I should have a lot better 60s. I was lettin the clutch out at about 5 grand and no tire slip, just need to learn no to be a punk and let the clutch out faster and get on the gas faster.
on 14" azenis i usually cut 2.1 60' times, last weekend at bradenton's drag track i cut a 2.0 60' time. practice does help, so does dropping the air pressure on the tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 »</TD></TR><TR><TD CLASS="quote">Suspension boyee.
</TD></TR></TABLE>the worst your suspension is, the worst your 60' times are going to be. those two go hand in hand, but like everything else suspension can only do but so much on for street tireson a fwd car
</TD></TR></TABLE>on 14" azenis i usually cut 2.1 60' times, last weekend at bradenton's drag track i cut a 2.0 60' time. practice does help, so does dropping the air pressure on the tires.
There are a couple of other things to consider. First, try getting a bushing kit. This will stiffen up your suspension and reduce the lag between your wheels going foreward and the car starting to move foreward. Another thing to do would be to adjust your camber. This requires a kit on most Hondas. But it can very significantly improve your contact patch. This is especially important with swapped Civics, as the extra weight of a B-series engine tends to make the front end sag, increasing negative camber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">This is especially important with swapped Civics, as the extra weight of a B-series engine tends to make the front end sag, increasing negative camber.</TD></TR></TABLE>
this is true my civic sits approx. a half inch lower in the front since my gsr swap
Vtecme92
Jul 11, 2006 02:56 AM
seadonkeyraypiss
Apr 23, 2003 10:45 PM
sushibug
10
May 27, 2002 09:18 AM
haha jk jk
