Front hub wheel stud replacement '96
Old Oct 15, 2004 | 06:27 AM
jchandler's Avatar
Default Front hub wheel stud replacement '96
Do the wheel studs have to be pressed in or can i tap them in with a hammer?
Old Oct 15, 2004 | 08:39 AM
boonacka's Avatar
Default Re: Front hub wheel stud replacement '96 (jchandler)
Once you get the hub off you can tap the studs off but you will most likely damage the threads unless you put the nut on it first.
Old Oct 15, 2004 | 08:59 AM
jchandler's Avatar
Default Re: Front hub wheel stud replacement '96 (boonacka)
What nut are you referring to? I just want to be sure that i don't ruin anything.
Old Oct 18, 2004 | 06:50 AM
boonacka's Avatar
wheel nuts
JDMJunior
Mar 26, 2006 09:34 PM
Excelerate
Jan 19, 2006 03:05 PM
SinTypeR
Dec 1, 2002 08:32 PM
