JDM ITR cluster question
Old Oct 15, 2004 | 06:09 AM
dAng! Kris's Avatar
Default JDM ITR cluster question
What cluster works in my 95 integra? Is it the 98 spec or the 96 spec? I know you have to move the electronics I think I'm just not really sure which one works or not. Thanks
Old Oct 15, 2004 | 10:45 PM
DC2_005200's Avatar
Default Re: JDM ITR cluster question (Frozty)
Well if you use the JDM ITR cluster then you should be cool. No need to rewire anything. BUT, if you want to go with a USDM ITR cluster, then you have to rewire some things. Why? Mostly because on the JDM ITR they did not come with an ABS system, thus no need for a ABS icon. But on the USDM ITR, they did come with ABS, thus you kinda got to rewire some things. But like I said, if it is a JDM ITR cluster 96 or 98, then it should just plug and play.
Old Oct 15, 2004 | 11:14 PM
dAng! Kris's Avatar
Default Re: JDM ITR cluster question (DC2_005200)
awesome thanks alot man, now i just need to find one
Old Oct 15, 2004 | 11:38 PM
BlueIntegraBoy's Avatar
A 96 spec will work in your 95. A 98 spec will require rewiring or something easier, swap the green film from the back of your cluster.
CHU-JDM-DC2
Aug 9, 2012 12:23 PM
NBPdEeCeE
Oct 2, 2007 10:20 AM
Calsonic
Aug 22, 2004 12:26 AM
