air fuel gauge not working properly?
Old Oct 15, 2004 | 01:56 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default air fuel gauge not working properly?
its an autometer and the shop that put it on cant figure out why it wont work we got another one saying it was defective but still the same problem anyone else have this same problem or show me how to wire it.
thanks for any help
Old Oct 15, 2004 | 07:07 AM
chitownrida's Avatar
what is wrong with it exactly? is it wired to the ecu harness?
Old Oct 15, 2004 | 07:48 AM
Elkins911's Avatar
Default Re: air fuel gauge not working properly? (raylude)
air fuel is the easiest thing to wire. it just splices into the O2 sensor. how could it be not working right?
Old Oct 15, 2004 | 11:47 AM
five-0's Avatar
Default Re: air fuel gauge not working properly? (Elkins911)
^^^^^^Useless.
That is not productive at all. I am competent and had problems with my A/F gauge install. It's electricity dude---- all kinds of shiz can happen. Let's try to help him out instead.
Raylude: What is it NOT doing?
Old Oct 15, 2004 | 02:47 PM
prelude994e's Avatar
Default Re: air fuel gauge not working properly? (five-0)
i agree you should def try to pin piont the main probelm (no power, readin wrong, etc), if its not getting power make sure you have a good ground, that was my problem a few months ago, stronger ground and a re check of the o2 sensor wire by the ECU and i was good to go........oh AND......dont forget a power source thats ON with ignition...... G.L.
Old Oct 15, 2004 | 03:45 PM
Eddiebx's Avatar
it would probably help if you stated what exactly is not working
Old Oct 15, 2004 | 04:35 PM
raylude's Avatar
Default Re: (Eddiebx)
it is goin from red to yellow at idle then i push the gas and it skips all the way to the verry last green dott they said they wired it rite then they upgraded the ground, they wired it to the upstream sensor but dont know how they wiered it exactly
Old Oct 15, 2004 | 08:36 PM
Eddiebx's Avatar
that probably normal, the autometer a/f guage sucks a fat one
Old Oct 15, 2004 | 09:51 PM
five-0's Avatar
Default Re: (raylude)
I believe at wide open throttle it will read rich. At half throttle it should bounce.
Old Oct 15, 2004 | 10:26 PM
PrettyLude's Avatar
yeah, its not the best gauge on the market but it will get you in the ballpark
Old Oct 15, 2004 | 10:49 PM
raylude's Avatar
Default Re: (PrettyLude)
really? then what is a good brand?
Old Oct 15, 2004 | 10:59 PM
the new AEM UEGO with guage ......its a wideband o2 sensor with digital read out in center of the gauge with the bouncing lights around the edges.....check out AEMpower.com you will see it
HondaH22a#1
Aug 23, 2008 12:40 PM
HondaPH22
Sep 11, 2006 11:35 PM
Yellb16crxsi
12
Apr 21, 2003 12:30 PM
OldSchoolSwap
Jan 26, 2003 11:28 AM
FOrSfEd
20
May 31, 2002 09:49 PM
