IB project motor dyno inside.
This motor has taken longer to build than anything I have done before. I am still waiting on a GSR head that I sent back East in February. The motor:
GSR block-sleeved by Dan Benson to 86mm.
Crower 92mm crank.
Cunningham LS length rods.
IB Spec Ultimate Wiseco 86mm pistons.
The head is a B16a head ported by Tom at Portflow.
Portflow valve springs. Portflow retainers.
JG custom sheetmetal intake manifold.
RPM 74mm throttle body.
RC 440cc injectors.
Hondata tuned by IB Jeff (thanks for all of your hard work buddy
Custom Prototype Racing intake.
Hytech big tube Type-R header.
Two sets of cams.
Toda 'D's fully tuned on run #23.
Swapped in some Skunk 2 Stage 2 cams on the dyno and tuned them until we got run #34. Not a world record, but I am happy with the results for now.
Peak hp:255.9
Peak torque:175.1
We dynoed this motor back in September with a stock ITR intake manifold, and it made killer torque (178 ft.-lbs.) at about 5,200 rpm, but the motor was suffocating at high rpm. The change to the custom JG intake dropped the peak torque a bit, but upper rpm power improved dramatically.
I would like to thank Jeff at Import Builders (again) for all of his help with this project, Tom at Portflow for a great deal of last minute help when I needed a head done (Tom, you are the man!), Dan Benson for another killer block, and Eugene at Prostreet for letting us monopolize his dyno for so long. Thanks again everybody who helped out
Crower 92mm crank.
RC 440cc injectors.
)Custom Prototype Racing intake.
Two sets of cams.
Peak hp:255.9
Peak torque:175.1
Very nice!!!!!!
Congrats to you and also Jeff@IB! I gotta talk to him soon, I haven't spoken to him since early early this year! Hopefully you get your OTHER HEAD soon andc redyno and see how much more power you will make!
Nice numbers indeed...
Sorry if this is a stupid question, but what's the compression ratio? I saw the 86mm Wiseco Ultimates but didn't see a CR, maybe im blind. But keep up the good work, I wanna se 9's outta that.. hahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KlawzOfDeath »</TD></TR><TR><TD CLASS="quote">Nice numbers indeed...
14.5:1 or more per the site
</TD></TR></TABLE>14.5:1 or more per the site
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdBoon »</TD></TR><TR><TD CLASS="quote">Awesome #s Todd. I'm really interested in seeing the power output when you get the RLZ head</TD></TR></TABLE>
Yeah, we should see that sometime in 2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Time for some ITBs...</TD></TR></TABLE>
I was thinking the same thing. And an AEM EMS for good measure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">maybe you should try BC 4s since they destroyed skunk2s on Tbone's motor. </TD></TR></TABLE>
I'd like to see this as well.
Those are some damn good #'s..... 175tq
What is this setup in? What is the comp ratio? This man definatly knows his **** and isn't a dick about sharing his knowledge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">I was thinking the same thing. And an AEM EMS for good measure.</TD></TR></TABLE>
Do it! I would love to see 270 whp
Guest
Posts: n/a
Wasn't that skunk2s stg3's not stg 2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FeatherWeight »</TD></TR><TR><TD CLASS="quote">
Wasn't that skunk2s stg3's not stg 2?</TD></TR></TABLE>
Yes but the sk3's killed the sk 2's on my motor beforehand.
I beleive Jeff has better luck with the skunk 2's over the 3's though.. Just goes to show what works for one wont always work for the other.
Good Job Todd and Jeff
sick tq
sick tq
