Best springs for stock shocks?
Old Dec 17, 2001 | 06:17 AM
Mike K's Avatar
Default Best springs for stock shocks?
Not looking for a coilover system or a sleeve-type spring.
Just looking for the best spring for handling, preferrably stiff as hell in the rear. Ride quality doesn't matter.
I have access to a set of Tanabe Sustec springs. The purple ones. Anyone have suggestions?
BTW, I am selling my A'PEXi WS coilovers if anyone is interested. They are about 6months old. Still work great. No rust. I live in Florida, remember.
Old Dec 17, 2001 | 06:20 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Best springs for stock shocks? (Mike K)
stock.
seriously, unless you want dat bitch to bounce, then I'd suggest H&R race springs.
Old Dec 17, 2001 | 06:47 AM
ITR764's Avatar
Default Re: Best springs for stock shocks? (Dave-ROR)
kg/mm, spoon... were a couple that were suggested to me. i'm thinking of getting kg/mm cause there cheaper than spoon and are the same spring rates. neither have stiffer rear rate like you looking for.
Old Dec 17, 2001 | 06:59 AM
BoM's Avatar
BoM
Default Re: Best springs for stock shocks? (ITR764)
here u go mike these are some spring rates i've collected...
not sure about their accuracy but their from past searches i've done.
stock type R - 247Front / 150-247 rear progressive
Neuspeed Race 2.00/2.00 500/450
H&R Race - 583F - 450R
these rates are too stiff for your stock shocks they'll start wearing fast...STOCK springs is best...
Old Dec 17, 2001 | 07:04 AM
BryanSprinkel's Avatar
stock
Bryan
Old Dec 17, 2001 | 07:07 AM
sackdz's Avatar
Isn't kg/mm just the spring rating? They're not a manufacturer.... or am I an idiot?
Old Dec 17, 2001 | 07:18 AM
cjb92's Avatar
Default Re: Best springs for stock shocks? (sackdz)
kg/mm is the manufacturer. I think it's a subsidary of H&R or something like that
Old Dec 17, 2001 | 07:24 AM
b00st-0wnz's Avatar
both actually.
Old Dec 17, 2001 | 07:29 AM
ITR00-816's Avatar
New User
What are the exact spring rates for the Spoon. I was told 6.5kg front/5.5kg rear.
Just want to double check!
Thanks
Old Dec 17, 2001 | 07:38 AM
Kengs's Avatar
Default Re: Best springs for stock shocks? (superflea)
Kg/mm is a Japanese company; nothing to do with H&R.
I have been told that the Kg/mm DR21 Sport springs are the most popular in Japan (for what that's worth).
http://www.kgm.co.jp/catalogue/dr21/dr21-frame.htm
Old Dec 17, 2001 | 07:55 AM
YodaIsGod
Guest
Posts: n/a
Default Re: Best springs for stock shocks? (BoM)
are those correct?
Old Dec 17, 2001 | 08:05 AM
ITR764's Avatar
Default Re: Best springs for stock shocks? (kengs)
damn, i was begining to think i was the only person who knew of kg/mm...
Old Dec 17, 2001 | 08:17 AM
b00st-0wnz's Avatar
Come on Keith, at least 3 of us said it was a manu.
Old Dec 17, 2001 | 08:23 AM
Mike M's Avatar
Founding Member
Nope Not the only one
Old Dec 17, 2001 | 08:27 AM
Preludster's Avatar
Actually "kg" means "Kilogramm" and "mm" means "Milimeter". It´s something like pound and inch. But I dunno if it´s a name of a brand.
I want to lower me future ITR too and somebody told me that I would be fine with springs when I´m not going to lower it more than about 1,6 inch. In the moment I´ve got the choice between H&R (about 1,4inch), ap (about 1,6inch) and DC-Sports (about 1,6inch). Which brand should I get? At first I wanted to buy a coilover system but he also told me that I wouldn´t be able to adjust it as perfectly as the stock suspension is! (And that´s very right I´d guess) The main reason why I want to drop it is because I really don´t like these gaps between the tires and the wheel-wells. And I´ve already asked this question in Purehonda, Automotiveforums, HondaSociety......but nobody could help me out with that! The only thing I know yet is that I will need a camber kit. SO PLEASE HELP ME AND GIVE ME AN IDEA WHAT I SHOULD GET!!! PLEASE!!! By the way, we don´t have got brands like Tein or anything else (japanese) like that over here and I won´t be allowed to use them by law. Thanx in advance!!!!
Old Dec 17, 2001 | 08:33 AM
BoM's Avatar
BoM
Default Re: Best springs for stock shocks? (YodaIsGod)
are those correct?
i think sooo i got them from here...but never know...alot of BS around here.
Old Dec 17, 2001 | 08:34 AM
Big Phat R's Avatar
Mike K: As the function of the shock absorber is to reduce the oscillations of the spring - it makes sense that the stock R damper is "tuned" to the spring rate. If you increase the spring rate without increasing the damping rate of the shock - you will just end up blowing the seals in your stock shocks - and your car will ride like a P.O.S.
If you just want a drop - go with aftermarket bolt-on springs by Eibach, H&R or Comptech. Use similar spring rates if possible. Stock is ~240 lb/in (4.3 kg/mm) with linear rate springs up front and progressive rate at the rear (which softens the bumps in the rear when it is not loaded).
Old Dec 17, 2001 | 08:36 AM
Kengs's Avatar
Default Re: Best springs for stock shocks? (DOHCVeetec)
You are referring to TUV certification? Probably best to stick with H&R or Eibach in your case.
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Yeah, I'm looking to buy some spoon springs off this one dude, but I don't want the car to handle worse. They only lower it 3/4" to 1"
Old Dec 17, 2001 | 08:37 AM
Preludster's Avatar
Default Re: Best springs for stock shocks? (Brian*Black99Si)
Yea, that´s possible! But can anybody help me with my problem?? I really don´t know what to do anymore! Springs or coilover system or springs and struts or .....Stupid gap....!
Old Dec 17, 2001 | 08:45 AM
ITR764's Avatar
Default Re: Best springs for stock shocks? (TypeRmsm)
well, i know you've heard of them. a few others as well, just supprised to see how many haven't.
Old Dec 17, 2001 | 08:55 AM
YodaIsGod
Guest
Posts: n/a
can someone please confirm the spring rates?
Old Dec 17, 2001 | 08:59 AM
ITR764's Avatar
just did some conversions and... the KG/MM springs lower 1.1" front with springs rates being 368.4 and the rear will lower .9" with the springs rates being 268.2. what are some thoughts about these springs killing the stock shocks??? spring rates are not that much higher than stock...
Old Dec 17, 2001 | 09:43 AM
Hukd Up's Avatar
h & r makes neuspeed.....does anyone know the rates of the neuspeed sport?
Old Dec 17, 2001 | 10:17 AM
Todd00's Avatar
I said I don't want a title!
The only way you are going to get what you desire is a set of sleeved coilovers. Then you can do something like 300ft/350rr and your stock shocks will still take it. Neuspeed/H&R, etc are all designed for safe "street" use.
