Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Oil cooler fitting size
Old Dec 17, 2001 | 05:51 AM
4doorH22's Avatar
Default Oil cooler fitting size
For those of you that have or are considering an oil cooler, what fitting size is recommended? AN-8, 10, or 12 (1/2", 5/8", or 3/4")?
Thanks.
Old Dec 17, 2001 | 06:00 AM
SOHCArchangel's Avatar
Default Re: Oil cooler fitting size (4doorH22)
AN-12 mang
Old Dec 17, 2001 | 11:27 AM
Spade's Avatar
Default Re: Oil cooler fitting size (SOHCkordVTEC)
The bigger the better.....you can't go wrong with a large size on the oil cooler.
Old Dec 17, 2001 | 11:45 AM
Mista Bone's Avatar
D Tranny Guru
12 is plenty, but 10 will work just as good.
Old Dec 17, 2001 | 11:47 AM
Andrew Sites's Avatar
Default Re: Oil cooler fitting size (Mista Bone)
I run -10 fittings throughout my oil cooler setup.
Old Dec 17, 2001 | 02:00 PM
jeff652's Avatar
Default Re: Oil cooler fitting size (Andrew)
-10 AN. Get too much bigger and you'll looose pressure with the lost velocity . . .
Jeff
Old Dec 17, 2001 | 02:08 PM
siisgood00's Avatar
New User
Default Re: Oil cooler fitting size (jeff652)
Damn jeff,, those pics are beautiful,, looks clean as hell
Old Dec 17, 2001 | 02:32 PM
4doorH22's Avatar
Default Re: Oil cooler fitting size (siisgood00)
Thanks, all. AN-10 it is.
One more question if I may, what exactly does an oil catch can do?
EDIT: Nevermind found it in a search
[Modified by 4doorH22, 6:39 PM 12/17/2001]
Old Dec 17, 2001 | 03:12 PM
GSRMatt's Avatar
25 Year Member
Pressure is inversely related to velocity. As velocity goes down, pressure goes up, and vice versa. The bigger issue is making sure you don't add any restrictions to flow between the pump and bearings that would artificially reduce pressure.
I used -10 for my Talon.
Old Dec 17, 2001 | 05:13 PM
johng's Avatar
[QUOTE
Jeff[/QUOTE]
Alright.....what am I looking at here?
Old Dec 17, 2001 | 07:27 PM
_unknown_'s Avatar
Default Re: Oil cooler fitting size (johng)
You are looking at a Canton Mecca oil fiter. I think...
riceball777
Jan 10, 2008 04:07 AM
RedPinoySi
Jun 12, 2007 05:23 PM
g2_boosted
Oct 13, 2004 10:52 PM
JohnShaft
Aug 22, 2001 12:09 PM
