removing p/s container
Old Oct 14, 2004 | 06:05 PM
hOndafienD 04's Avatar
Default removing p/s container
...but still keeping power steering...can this be done? if the lines were all filled and such and somehow connected would i be possible? im trying to clean up the engine bay a little bit so it can be easier to work on...
Old Oct 14, 2004 | 06:39 PM
spnbb2
Guest
Posts: n/a
do you mean the fluid resevoir or the ps unit itself?
Old Oct 14, 2004 | 08:21 PM
92LudeSI's Avatar
I think he means the resevoir. I suppose you could relocate it but I doubt you could just eliminate it.
Old Oct 15, 2004 | 03:13 AM
ryanstev's Avatar
Default Re: removing p/s container (hOndafienD 04)
You could remove it, but the problem would be making sure you had absolutely no air in your P/S lines, which you wouldn't be able to do easily at all.
Also what happens when you want to check your level and top up, etc?
Old Oct 15, 2004 | 09:44 AM
where could i relocate the resivoir to?
Old Oct 15, 2004 | 11:47 AM
sniffthese's Avatar
Default Re: (hOndafienD 04)
You might as well just take out your p/s...Ryanstev has a point their..
london ritzler
Jan 15, 2013 07:23 PM
98vtec
Oct 2, 2009 10:20 AM
erikiksaz1
Suspension & Brakes
Jul 31, 2009 12:36 AM
accord478
Apr 10, 2007 10:44 AM
