dose anyoe know the size of my connecting rod bearings
Old Oct 14, 2004 | 05:37 PM
waxbunny's Avatar
Default dose anyoe know the size of my connecting rod bearings
i need to know the size of the connecting rod bearings in my 96 gsr.
acura sells the bearings only in colors and not sizes and they have no refrance of size to color. i need to know the sizes of the colors so i can get the right size ones for my crankshaft, otherwise i have to buy one of each color and find out wich one will fit my cars crankshaft and that will be a little costly.
can anyone help me?
Old Oct 14, 2004 | 06:16 PM
mmuller's Avatar
Mad Scientist
Default Re: dose anyoe know the size of my connecting rod bearings (waxbunny)
have you looked at the #'s stamped on the block/ crank?
match them up and then you can get the colors (or approx.) that you need.
Old Oct 14, 2004 | 07:51 PM
Muckman's Avatar
Moderator in Chief
Like mmuller said, the bearing codes are stamped on the block. You can also try a set of ACLs which are the "middle OEM" size of green.
If you want to rebuild your engine right you should plastigauge your bearing clearances using your old bearings as a reference of size. And then order new bearings according to your measurements, depending on if you need a smaller or bigger clearance.
97grnrs
May 8, 2007 07:21 PM
waxbunny
Oct 14, 2004 06:12 PM
made in JAPAN
Jun 16, 2004 07:54 PM
bunnyrabbit
Mar 29, 2004 05:20 AM
vteec
Jan 14, 2004 01:08 PM
