3" exhaust overkill on my car?
Old Oct 14, 2004 | 03:22 PM
HeikDiesel's Avatar
Default 3" exhaust overkill on my car?
I have an all motor h22 with itb's, custom cams, 14:1 compression, and an AN-R header. I was wondering if I should keep the 2.5 trend, or if I should step up to 3" from the header back
Old Oct 14, 2004 | 04:05 PM
RobDealakaGSRswapandslow
Guest
Posts: n/a
3"
Old Oct 14, 2004 | 04:53 PM
HONDA_TYPE_R's Avatar
Default Re: (RobDealakaGSRswapandslow)
I would say if you are putting out similar numbers (besides torque) to a turbocharged car, get the 3". From what you listed...get the 3". You have to have at least 230+whp...probably more.
Old Oct 14, 2004 | 06:14 PM
HeikDiesel's Avatar
Default Re: (HONDA_TYPE_R)
thanks for the imput
Old Oct 14, 2004 | 06:27 PM
boosted k20's Avatar
Default Re: (PhatAcuraIntegra)
14.1 compression .... DAMN!!!!!!!!!!!!!!!!!!!!!!
Old Oct 14, 2004 | 06:49 PM
87b16crx's Avatar
and to think, that car used to be turboed. good to see my old car coming to this. NA is best bishes.
Old Oct 14, 2004 | 07:05 PM
HeikDiesel's Avatar
Default Re: (87b16crx)
word up.
Old Oct 14, 2004 | 10:59 PM
racingfan's Avatar
3" will be loud...
Old Oct 15, 2004 | 08:06 AM
arw321's Avatar
Default Re: (APEX'i Baby N1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX’i Baby N1 &raquo;</TD></TR><TR><TD CLASS="quote">3" will be loud...</TD></TR></TABLE>
Seriously, I don't think he gives a **** if it's loud. I'm sure it's not exactly an everyday driver.
Old Oct 15, 2004 | 09:35 AM
B00ST2nR's Avatar
Default Re: (arw321)
a nice header system like SMSP or Hytech have 2.5" inch collectors. A nice flowing 2.5" inch exhaust will do just fine.
3" inch might be an overkill for an All-Motor setup, unless you go all out and plan to max it out.
Old Oct 15, 2004 | 11:02 AM
sleepycivichb's Avatar
3" exhaust will work perfectly fine with that big of a motor and that much compression, just make sure you have a good flowing header and resonate that exhaust so you don't loose too much back pressure. nice sounding setup btw! -Jason
Old Oct 15, 2004 | 11:20 AM
4x4integra's Avatar
Default Re: (sleepycivichb)
2.5 is fine dogz.3'' is to goddamn much
Old Oct 15, 2004 | 02:38 PM
HeikDiesel's Avatar
Default Re: (4x4integra)
so what is it then, some of you guys say overkill, some say its cool. This isnt gonna be a daily driver so im not too worried about loudness.
Old Oct 16, 2004 | 06:57 AM
Just go with 3" and put a resonator or two in there, such as a carsound cat. You will be happy you made that decision.
-Jason
Old Oct 16, 2004 | 08:24 AM
HeikDiesel's Avatar
does carsound make a cat that will have a 2.5" collector to attach to my header and a 3" to attach to my exhaust
Old Oct 16, 2004 | 10:40 AM
i'm pretty sure they do. the search button is the key! -Jason
Old Oct 16, 2004 | 12:05 PM
zad5's Avatar
Default Re: 3" exhaust overkill on my car? (PhatAcuraIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">I have an all motor h22 with itb's, custom cams, 14:1 compression, and an AN-R header. I was wondering if I should keep the 2.5 trend, or if I should step up to 3" from the header back</TD></TR></TABLE>
dont tell me you run it on the street. even if you do i say run open header
Old Oct 16, 2004 | 01:20 PM
HeikDiesel's Avatar
Default Re: 3" exhaust overkill on my car? (zad5)
i plan on bringing it out occasionally
Old Oct 16, 2004 | 01:40 PM
Mr Hammond's Avatar
a/k/a Jomo
Header back? This set-up sounds like no street car I've heard of. If it is you're nuts. Custom side exit w/ 3" collector.
Old Oct 16, 2004 | 01:46 PM
HeikDiesel's Avatar
Default Re: 3" exhaust overkill on my car? (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">
Header back? This set-up sounds like no street car I've heard of. If it is you're nuts. Custom side exit w/ 3" collector.</TD></TR></TABLE>
I thought about doin that. Its really not a street car, I just want to be able to bring it out and drive around once a month or so
Old Oct 16, 2004 | 04:29 PM
Waachback's Avatar
3 inch is fine for that amount of HP IMO...
IntegraType-R
12
Jun 15, 2008 08:19 AM
LILSOWEK
Mar 18, 2007 12:05 PM
91preyludesi
21
Jan 1, 2006 05:23 AM
Jordans95si
Aug 3, 2005 05:28 PM
h22a193
Feb 15, 2005 05:31 PM
