Fuel Pump wont turn on
Old Oct 14, 2004 | 01:02 PM
JDMlyfestyle's Avatar
Default Fuel Pump wont turn on
well i got all the car together and when i tried starting the car it turns over but wont start but i dont hear the fuel pump starting. checked my Fuel Pressure Gauge and its at 0. is there any wires for the fuel pump in the engine bay or does it come right out of the ECU. is there any thing else i can check that controls the fuel pump?
Old Oct 14, 2004 | 01:10 PM
b18c1eg
Guest
Posts: n/a
Default Re: Fuel Pump wont turn on (JDMlyfestyle)
I know I've had issues with fuel pump relay switches in Civic's going bad. I don't know your entire situation, but they may be something to look into. It is located on the drivers side kick panel area.
Need to know more info about your setup and what all you've done since the last time you started the car.
Brad
Old Oct 14, 2004 | 01:12 PM
2fast4u831's Avatar
I'm really 2slow
might wanna check the main relay
Old Oct 14, 2004 | 01:14 PM
civiccpedx's Avatar
Default Re: (2FAST4U831)
check your main relay. If the fuel pump isn't priming that should be the problem.
Old Oct 14, 2004 | 01:25 PM
the car cranks over. it tries to start but still getting no fuel. what wires on the wiring harness run to the fuel pump? but if it was the main relay i wouldnt have power to crank it over or any thing would i?
Old Oct 14, 2004 | 01:26 PM
civiccpedx's Avatar
Default Re: (JDMlyfestyle)
I thought the main relay was just the fuel pump, I don't think that it affects anything else like the ability for the engine to turn over. Someone correct me if i am wrong.
Old Oct 14, 2004 | 02:48 PM
the only thing i can hear clicking is the under hood fuse box ( i brough it inside the car. all the connections are still there and nothing else has changed.
Old Oct 14, 2004 | 03:43 PM
is there any way to test the main relay if it is bad?
Old Oct 15, 2004 | 09:17 AM
Mike1486's Avatar
been having trouble with my pump as well... one day it works fine then the next my engine is getting barely enough gas. I think its a bad pump... but if the relay malfunctions during driving can that be a cause? Its been giving me a headache now for about 2 weeks or so. Im taking it in to the mechanic today to have it checked out :-\ hope it doesnt cost much :: crosses fingers ::
Old Oct 15, 2004 | 09:39 AM
EE_Chris's Avatar
Default Re: Fuel Pump wont turn on (Mike1486)
There isn't too much to the circuit. Do you have a meter in order to check for shorts/opens/voltages??
Old Oct 15, 2004 | 09:41 AM
Luserkid's Avatar
Default Re: Fuel Pump wont turn on (EE_Chris)
Try the fuel pump switch :
Old Oct 15, 2004 | 09:42 AM
Tony Starks's Avatar
Once upon a time I had the same problem. Ended up being the relay. Honda gets like $50 for it. Civics are notorious for this.
Old Oct 15, 2004 | 10:21 AM
Relic1's Avatar
the main relay.... fix it yourself in 30 minutes. max.
http://www.markl.f9.co.uk/howt...y.htm
Old Oct 15, 2004 | 10:56 AM
r_Senik's Avatar
Default Re: (Relic1)
main relay or ignition switch
Old Oct 15, 2004 | 10:14 PM
yo yo need more help yo
Old Oct 15, 2004 | 10:15 PM
oh yeah, yo yo bump yo
Old Oct 16, 2004 | 05:03 AM
EE_Chris's Avatar
What do you want - someone to walk over to your place with a multimeter and troubleshoot for you??
The entire schematic for the fuel pump circuit has been posted - now its your turn to play detective.
Have you checked the fuses? Have you visually inspected the Main Relay for cold solder joints? Do you have a meter?
The schematic is the same for all Civics and Tegs - just the pin#s are different. Do you need different pin #'s then what is shown? If yes, it'd help to post up info on what car/engine/ECU you're using.
Old Oct 16, 2004 | 06:14 AM
2lua's Avatar
honda is bad for the main relay. remove it and check for the solder joints connection inside. resolder the joints.
Old Oct 16, 2004 | 08:42 AM
The main relay has been tested everything looks good. tested the OHM's and its getting conuity. everything is working fine on there. Im Running a EG with a B16a2 and Mugen P28. Also i bought a Brand new Main relay yesterday from honda and still nothing working.
Old Oct 16, 2004 | 08:49 AM
Turbogixxer's Avatar
you check power to the pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">The schematic is the same for all Civics and Tegs - just the pin#s are different. Do you need different pin #'s then what is shown? If yes, it'd help to post up info on what car/engine/ECU you're using.</TD></TR></TABLE>
OBD1 pinouts are in my sig.
Old Oct 16, 2004 | 09:14 AM
SOHCejcivic's Avatar
Default Re: (turbogixxer)
could even just be a fuse. had the same problem with my buddies del sol. it's in the engine bay fuse box and it's the ajx/agj or something spot.
Old Oct 16, 2004 | 09:21 AM
r_Senik's Avatar
ignition switch? same thing happen to my uncles lude.
Old Oct 16, 2004 | 09:47 AM
EE_Chris's Avatar
Default Re: (r_Senik)
Are fuses 31 (ECU, 15A, underhood), fuse 12 (without SRS, 15A, underdash), and fuse 18 (7.5A, underdash) all good (these fuses are from the 95 Civic Helms ETM)?
If yes: On pin 7 of the Main Relay, is there battery voltage? On pin 5, with key 'on or start', is there battery voltage? On pin 2, with engine cranking, is there battery voltage?
If voltage from the ignition switch never makes it to the Main Relay with the key 'on or start', the ECU will never gets it voltage which means it will never provide a ground to close the fuel pump set contacts.
Old Oct 16, 2004 | 10:20 AM
Combustion Contraption's Avatar
unhook your battery for 5 minutes hook it back up and try again.
as odd as that sounds, it actually worked for me about 3 weeks ago when my fuel pump wasnt priming. i checked all the fuses, none were blown, so i just gave this a shot and it worked.
Old Oct 16, 2004 | 11:02 AM
Do_Ster's Avatar
jdmlifestyle, check your fuses. it's a fuse called the ACG i think. it gives symptons of a bad main relay or fuel pump. keep us posted.
