What would you put setting for Koni Yellow on the street?
Old Dec 16, 2001 | 09:33 PM
shpae's Avatar
New User
Default What would you put setting for Koni Yellow on the street?
I had driven Koni and H&R with soft setting for 2 weeks, i just changed to Firm(all the way)setting 2hrs ago. Ride is really stiff but car's handling is awesome!
I just wonder you guys who installed Koni Yellow, what setting you prefer on the street?
Old Dec 16, 2001 | 11:35 PM
grndcont's Avatar
Default Re: What would you put setting for Koni Yellow on the street? (shpae)
3\4 in rear, 1\2 up front
Old Dec 17, 2001 | 03:29 AM
Black SVT's Avatar
Default Re: What would you put setting for Koni Yellow on the street? (grndcont)
I wouldn't leave them at full stiff for street use I have seen people damage the shocks that way.
Old Dec 17, 2001 | 03:49 AM
Neo's Avatar
Neo
That's exactly what mine are set at. 3/4 turn in rear is about 42% firm (of total stiffness); 1/2 turn is about 28% firm. All depends on your preferences, but more importantly you should try to match the dampening rate to the spring rates of your H&Rs. As far as I know, there is no tried and true way to match shock dampening rates to spring rates, except trial and error. Off the shelf Koni yellows/sports are supposed to handle spring rates of up to 600 ft/lbs. So, basically if your springs are 300 ft/lbs (for example), then those shocks should be set at around 50% stiff, + or - whatever really helps the car "feel" better.
[Modified by Neo, 8:16 AM 12/18/2001]
Old Dec 17, 2001 | 10:18 PM
proton's Avatar
Default Re: What would you put setting for Koni Yellow on the street? (Dc2k-specR)
You can damage shocks if you put them at full stiff?
Does that mean that stiffer shocks, in general, don't last as long as softer shocks non-adjustables, I mean)?
Deminmatthew
Suspension & Brakes
Aug 5, 2012 06:26 AM
Chillinit
Nov 25, 2009 11:11 AM
performula
Oct 21, 2002 05:38 AM
slimbo
Sep 23, 2002 05:21 AM
Ludehrt
Aug 2, 2002 11:16 AM
