JDM b16 OBD0 in 92 CX hatch not starting
Old Oct 14, 2004 | 07:05 AM
ImThatGuy's Avatar
Default JDM b16 OBD0 in 92 CX hatch not starting
ok I have posted alot about this recently, we have b16a3 dizzy from 95 del sol, chipped p28 ecu an everything wired to obd1 spec I think, an the obd0 injectors hard wired in an the car won't start, we put new plugs in puts it to TDC, tweaked the dizzy timing an all we get is a back fire every once in a while, please someone help me here this is stressing me the hell out we have spark an fuel, but it won't start
Old Oct 14, 2004 | 10:54 AM
n1div's Avatar
If you're using OBD 0 injectors, I'm assuming you're also using the injector resistor box? If not, there's your problem.
Old Oct 14, 2004 | 11:11 AM
dantastic's Avatar
pull off your valve cover and check ur timing
Turboredteg
15
Oct 14, 2011 03:06 PM
Das Bar 2k4
Oct 18, 2006 05:46 PM
camboMONK
14
Dec 8, 2005 08:11 AM
TooDrunk2See
Oct 25, 2003 01:59 PM
