Stock side skirt removel
Old Oct 13, 2004 | 07:40 PM
jcool5's Avatar
Default Stock side skirt removel
I Have a 4-door 2000 honda civic and i tried to remove the screws under the car that hold the stock side skirts on, i could not figure it out and broke one of them. Can anybody tell me the process in taking those special screw things out?? thanks
Old Oct 13, 2004 | 07:42 PM
Built Beast's Avatar
Default Re: Stock side skirt removel (jcool5)
remove the screws, the just slide to the front or back...can't remember which it is they come right off.
Old Oct 13, 2004 | 07:48 PM
Prod's Avatar
theres like 5 screws at least on each skirt, 3 or 4 metal ones and a couple plastic ones...then like he said it just slides forward and off
Old Oct 13, 2004 | 07:55 PM
jcool5's Avatar
Default Re: Stock side skirt removel (Prod)
so the plasic screws slide off or what??, because i tried to unscrew the plastic one and i ended up poping one off with a screwdriver(it did break)
Old Oct 13, 2004 | 07:57 PM
beastly3
Guest
Posts: n/a
what the hells wrong with u asking a question like that, are u blind missing fingers or a female......better be one if not you dont deserve a damn honda, get a damn bus pass and some change, and smack ur mother for raising you this way.... im sick right now! eat **** im aloud to express my feelings mods...dont ban me for the 5th time......i love HT eat **** sideskirt boy
Old Oct 13, 2004 | 08:12 PM
green-'s Avatar
Default Re: Stock side skirt removel (beastly3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastly3 &raquo;</TD></TR><TR><TD CLASS="quote">what the hells wrong with u asking a question like that, are u blind missing fingers or a female......better be one if not you dont deserve a damn honda, get a damn bus pass and some change, and smack ur mother for raising you this way.... im sick right now! eat **** im aloud to express my feelings mods...dont ban me for the 5th time......i love HT eat **** sideskirt boy </TD></TR></TABLE>
wow....reported.
Yeah the skirts slide off when you get the screws out. Pretty easy actually when you figure it out.
Old Oct 13, 2004 | 08:13 PM
Castor's Avatar
Ooooosaaaaaaa...
Old Oct 13, 2004 | 08:19 PM
Default Re: Stock side skirt removel (Castor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Castor &raquo;</TD></TR><TR><TD CLASS="quote">
Ooooosaaaaaaa...</TD></TR></TABLE>
hahhahahaha, some Bad Boys 2 ****...
Old Oct 13, 2004 | 08:26 PM
turbotime's Avatar
TO TOPIC STARTER ^ ignore this fool, he spends his time browsing H-T boards looking for posts which he can bitch about as some substitutionary way of dealing with his repressed and definitely dysfunctional childhood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastly3 &raquo;</TD></TR><TR><TD CLASS="quote">im aloud to express my feelings mods...dont ban me for the 5th time...... </TD></TR></TABLE>
You get banned because your a flaming dumbass, as exemplified by your post....
As for your sideskirt question, like the other non-******** said, should be a few screws holdin it on, then just slide forward (or back, not sure) should come right off...
Old Oct 14, 2004 | 04:57 AM
Prod's Avatar
the plastic screws just unscrew and then iirc you can pull down on the sideskirt and the little plastic clip they screw into will pop out and fall on the ground, just be careful with them when unscrewing. The sideskirt it self is the only part that actually slides off
Old Oct 14, 2004 | 09:25 AM
gftgrill's Avatar
those black plastic clips underneath are a bitch. you have to pop out the center part, then pull that out. after that the outter part of it should pull/fall out. don't worry I brok about 6 of mine when I changed my side skirts. you don't need them as long as you put the screws at the front and back in.
after removing all of those clips and the srews the whole piece slides towards the front of the car. then you pull it off. there are sever clips behind the skirt that holds it to the car.
good luck
Old Oct 14, 2004 | 10:29 AM
StRacer's Avatar
Yea some of the plastic ones might break, so you might want to go to autozone and get some replacements.
chelt_scene
12
Jul 5, 2009 07:26 PM
Protoss
Mar 9, 2006 04:42 PM
TMNcivic
Audio / Security / Video
Mar 5, 2005 02:15 PM
slvrcivic97
Jul 15, 2003 09:10 PM
citanest
Jul 22, 2001 08:51 PM
