do i need motor mounts?
Old Oct 13, 2004 | 05:18 PM
.Rex's Avatar
Default do i need motor mounts?
My idle is really shaky. It vibrates alot and the engine really moves quite a bit... will motor mounts fix the problem or what do i need? where can i find them? Thanks
Old Oct 13, 2004 | 05:25 PM
civictildeath's Avatar
Default Re: do i need motor mounts? (CarbonCivic)
what rpm does it idle at??
Old Oct 13, 2004 | 05:28 PM
.Rex's Avatar
Default Re: do i need motor mounts? (civictildeath)
its regular idle idk cause there is no tach in it.. its not a hight idle... its just when it running and I open the hood, its vibrating ALOT
Old Oct 13, 2004 | 05:30 PM
probably need them then might as well get the polyurethane mounts while your at it better than stock replacements
Old Oct 13, 2004 | 05:32 PM
.Rex's Avatar
ok, its a D series motor so where can i get them? website?
Old Oct 13, 2004 | 05:42 PM
http://www.spiderautomotive.com/motmounforho.html
Old Oct 13, 2004 | 05:45 PM
.Rex's Avatar
thats not for a 92 civic
Old Oct 13, 2004 | 05:46 PM
.Rex's Avatar
nvm it is... thanks tildeath!
Old Oct 13, 2004 | 05:54 PM
http://www.shopresponse.com/en....html
Old Oct 13, 2004 | 06:18 PM
dantastic's Avatar
fyi, stiff aftermarket mounts can transmit a bit of vibration into the cabin. i have ES inserts in my torque mounts and rear tranny mount. the motor barely moves when i rev it, but i get a pretty healthy vibration in my cabin. its just a bit shaky at idle
genetsang
Sep 30, 2023 05:15 PM
shraz
Honda Civic (2006 - 2015)
Jan 13, 2009 10:33 AM
91teg420
Feb 17, 2008 05:01 PM
TypeR0582
Jan 29, 2008 08:47 AM
Mr Boston
Aug 7, 2002 10:44 PM
