ZC/Z6 cam/ignition timing, help please!
Old Oct 13, 2004 | 02:37 PM
D21X's Avatar
Default ZC/Z6 cam/ignition timing, help please!
Ok i've got a ZC block with a Z6 head. I'm using a Z6 timing belt, so when i put the timing belt on the cam gear, which way is advanced/retarded on the cam gear? Im assuming toward the front is advanced and toward the rear is retard right? Does anyone know how many teeth im going to be off on the cam gear?
Since the cam gear is going to be off, do i have to fix my ignition timing also? Say i advance my cam gear, do i retard or advance my ignition timing? What5s the general rule of degrees/teeth advanced to degrees retard/advanced on ignition timing? thanks!!!
Old Oct 14, 2004 | 09:27 AM
D21X's Avatar
Default Re: ZC/Z6 cam/ignition timing, help please! (D21X)
anyone?
EJ6sedan
Dec 22, 2009 01:27 PM
johnwohl
May 17, 2009 12:27 PM
O16581724 5 2 5
Jul 5, 2006 07:29 AM
D21X
Oct 16, 2004 03:37 PM
d15maverick
May 3, 2004 09:14 PM
