12.2 Wilwood Brake kit and Team Dynamics 15*7 wheels?
Old Oct 13, 2004 | 12:12 PM
jwaked's Avatar
Default 12.2 Wilwood Brake kit and Team Dynamics 15*7 wheels?
I remember some talking about this but couldnīt find the post. I was told that the 12.2 Wilwood brake kit also sold by Fastbrakes would fit under the 15*7 Team Dynamics Pro Race 1 Wheels on my DC2 Integra. Anyone has any imput.
Thanks guys.
Jay
Old Oct 13, 2004 | 12:40 PM
PrettyLude's Avatar
its not going to fit a 15" rim
Old Oct 13, 2004 | 12:58 PM
jwaked's Avatar
Default Re: (PrettyLude)
They keep saying that it does fit. Fastbrakes told me that they do fit and have done it many times.
Jay
Old Oct 14, 2004 | 05:36 AM
turboteg2nv's Avatar
Default Re: (jwaked)
that's pretty incredible. how much for the whole setup? This is something i'm looking for too
Old Oct 14, 2004 | 06:46 AM
jwaked's Avatar
Anyone?
Old Oct 15, 2004 | 05:40 AM
jwaked's Avatar
No one has had eny experience with this set up?
Old Oct 15, 2004 | 05:47 AM
drdisco69's Avatar
Sometimes you can get a template from the manufacturer that will allow you to see if there is any interference. But if they say they've done it many times, that has to count for something, right?
Old Oct 15, 2004 | 06:33 AM
jwaked's Avatar
It does count and I have had good experiences with Brian at Fastbrakes, but lots of posts here have mentioned that 12.2" brakes wonīt fit under 15s. Thats why I am a bit confused and wanted to know if anyone has done it.
Old Oct 15, 2004 | 07:04 AM
rastropovitch
Guest
Posts: n/a
there is no way wilwoods 12.19" rotor/four piston caliper will fit uner a 15" rim without a huge offset/shim. the calipers are not low profile and require at least 16" rims, and even some of those do not fit.
Old Oct 15, 2004 | 07:09 AM
drdisco69's Avatar
Default Re: (MSchu)
Maybe I'm missing something, but how will the diameter of the wheel affect the caliper to spoke clearance. If you can fit it on a 15 with a different offset or hub spacer, then a 16 has no more to offer than 1/2 inch on the outside of the caliper. You will still have the same clearance problems to the spokes with the same offset and spoke design.
I think there are 2 issues, whether it will fit under a 15 inch wheel with sufficient offset, and whether it will fit under the spokes on the offset of the wheels he has.
Old Oct 15, 2004 | 07:15 AM
rastropovitch
Guest
Posts: n/a
Default Re: (drdisco69)
but of course... I have been runing these brake for YEARS... I have several sets to swasp in and out as needed(when they need to be rebuilt), the two issue are related though
And I Pity the Fool
Schu
Old Oct 15, 2004 | 07:17 AM
jwaked's Avatar
The offset is +45.
Old Oct 15, 2004 | 07:21 AM
rastropovitch
Guest
Posts: n/a
+45 is fine for the offset... if the fintment is very close you can actually file the edge of the caliper down ti fit correctly. You really only need a minimum of clearence for it to work. And if you do use a file to trim the edge off the caliper, do it very carefully and only a small amount of material.
Old Oct 15, 2004 | 09:06 AM
TurboJesse
Guest
Posts: n/a
Default Re: (MSchu)
im sure you could make it work....i know it fits over the fastbrakes kit
Old Oct 15, 2004 | 09:52 AM
rastropovitch
Guest
Posts: n/a
Default Re: (Mpir3)
does the FB kit use oem rotors or wilwoods 12.19 two piece rotor? I don't think the big rotor set up is going to fit
Old Oct 15, 2004 | 11:00 AM
jwaked's Avatar
Does not say on his website but it does say this about the wheels:
"Here is a 15" lightweight race wheel that will clear all the Fastbrake brake kits up to 12.2", no matter which one you choose. These wheels are designed to use large calipers and rotors and have LOTS of clearance. 15x7 with many offsets from +28 to +45 with the 4x100 bolt pattern. Most common is +40 or +45. With these offsets wheel to strut clearance is VERY TIGHT."
Old Oct 15, 2004 | 11:02 AM
jwaked's Avatar
Mpir3, have you seen them? Any info on why you think they would fit with be great.
Jay
philcivicjordan
Suspension & Brakes
21
May 13, 2018 01:16 AM
EG Coupe Frank
Suspension & Brakes
Mar 7, 2012 07:17 PM
SlowB16
Jun 10, 2008 07:40 AM
jwaked
165
Dec 31, 2004 04:28 PM
