fiberglass work help
Old Oct 13, 2004 | 10:57 AM
94_del_sol's Avatar
Default fiberglass work help
ive got a 9 inch crack in my ground effects what do i need /need to do to fix them
Old Oct 13, 2004 | 11:16 AM
McDade's Avatar
Default Re: fiberglass work help (94_del_sol)
we need some more info to help.
how did you get the crack?
where on the ground effects is it?
are your ground effects made from fiberglass or some kind of urathane?
Old Oct 13, 2004 | 11:23 AM
Synapse Motorsport's Avatar
If it is fiberglass, its an easy fix, just get back to us, and youll be on your way.
Old Oct 13, 2004 | 06:47 PM
eHoward's Avatar
Take the part off. Then run some fiberglass behind the crack. Let it cure. Then apply bondo(or some higher end equivilent) over the the front and smooth it out. Repaint.
Easy.
Old Oct 16, 2004 | 05:15 PM
fuzzynutz's Avatar
Default Re: (eHoward)
the way i used to fix small cracks was to tunnel out the crack about a 1/4 inch per side and about twice as deep then cut small strips of mat the size of hte tunnel and build it up level. then i would cut a few larger pieces of mat out and cover over the whole grinded area let it kick off and sand it down then bondao that mo fo up and prime it, it allways worked for me give it a try
Old Nov 13, 2004 | 12:38 PM
B18Tahtaras's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eHoward &raquo;</TD></TR><TR><TD CLASS="quote">Take the part off. Then run some fiberglass behind the crack. Let it cure. Then apply bondo(or some higher end equivilent) over the the front and smooth it out. Repaint.
Easy.</TD></TR></TABLE>
Drill a hole at the end(s) of the crack. That way it dosent continue to split then do the fiberglass/bondo work.
Old Nov 14, 2004 | 05:59 AM
boosted3g's Avatar
Default Re: (B18Tahtaras)
take a grinding wheel and roughen up the suface on the back side. Then lay some fiberglass matting on the back side. Youll be fine. easy fix
Old Nov 14, 2004 | 09:27 AM
crxhybrid85's Avatar
Default Re: (boosted3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuzzynutz &raquo;</TD></TR><TR><TD CLASS="quote">the way i used to fix small cracks was to tunnel out the crack about a 1/4 inch per side and about twice as deep then cut small strips of mat the size of hte tunnel and build it up level. then i would cut a few larger pieces of mat out and cover over the whole grinded area let it kick off and sand it down then bondao that mo fo up and prime it, it allways worked for me give it a try </TD></TR></TABLE>
This would be the best way to do it. Although it may be overkill(it's what I would do). What I used to use was something we called "angel hair". You take a peice of fiberglass and cut it up into real small pieces, then mix that with your resin. It makes kind of a thick goopy fiberglass glue. Then lay a thin piece over the top and sand her smooth when it cures. Also reinforce the back with some thicker matting.
Old Nov 14, 2004 | 12:12 PM
boxybutfast's Avatar
I use this stuff called West Systems Epoxy. It is stronger than the fiberglass and if done properly is very easy to use and very strong. You can find more info about it here:
http://www.westsystem.com/
It's most commonly found at boat supply stores
They have different fillers and uses instead of using bondo, which is soft, and you can use it with fiberglass cloth or if you're really industrious make something with carbon fiber cloth.
BTW: I would rather have fiberglass instead of urethane because of it's ease of repair.
Old Nov 25, 2004 | 01:01 PM
Default Re: fiberglass work help (boxybutfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boxybutfast &raquo;</TD></TR><TR><TD CLASS="quote">
BTW: I would rather have fiberglass instead of urethane because of it's ease of repair.</TD></TR></TABLE>
Doing alot of repairs... i have found that urethane is alot easier to fix when you know how. Not alot of people really know where to start with urethane... but with a good heatgun and the right glue... you're on your way rather nicely.
xtremvw
Sep 29, 2011 07:02 PM
NAgixxer
Feb 15, 2004 01:35 PM
darkirony
Oct 2, 2002 12:22 PM
hioctane3
Apr 26, 2002 05:33 AM
