RSX rotors on itr?
wondering if anyone has tried rsx rotors on an itr or is thinking about it? would make a great brake kit, eh fastbrakes?
Mike K, if you have time, can you measure the rsx front rotors for:
1. height from the top face of the rotor brake surface to the top of hub surface (ie checking the offset to see if i can use my current wheels)
2. thickness of the rotor
tia for your answers
Mike,
thanx for the suggestion. is that what you are using on your track car?
what is the size of the s2k rotors, thickness and hat height? i have to use 3rd party calipers as i'm trying to squeeze this into 15" race wheels.
henry
RSX rotors will not fit to ITR cuz the hat of the rotor (which is the part go over the hub) will not fit.
The rotors are 300mm in size and 28mm in thickness. If you can machine abit off from the inner hat then you can fit them with RXS calipers and rotors together.
