finished battery relocation pics.
Old Oct 13, 2004 | 09:31 AM
twkdCD595's Avatar
Default finished battery relocation pics.
I just ran a big high quality welding cable from the fuse box-> starter-> battery. also ran a ground all the way back to battery. made up a couple extra engine grounds too. nothing very difficult or extravagent. (all original battery terminals/ cables, supporting brackets, etc. all removed.)
anyways to the pics of the battery in the back... the pics were huge so I put them here and it resized them a bit.
http://photos.yahoo.com/twkdcd595@sbcglobal.net
took off the axle back exhaust, and then the heat shield (3 10mm bolts) used 4 big fender washers (painted black) with lock washers and teflon nuts on 1/4" stainless bolts... it is solid as a rock. the black under it is thin high density foam so it does not tear up either car or bottom plate. I like the billet look and it is super strong, 1/2" bottom and 1/4" top w/ a little ball milling.
Modified by twkdCD595 at 12:44 PM 10/13/2004
Old Oct 13, 2004 | 09:50 AM
gaydm.accord's Avatar
thanks for the write up
what gauge wire is that? and where can i acquire some... i was thinking about using a 0 or 2 gauge speaker wire before. im in the process of gathering parts together for this DIY myself.
where did you get that battery holder?
Old Oct 13, 2004 | 10:00 AM
twkdCD595's Avatar
Default Re: (gaydm.accord)
yeah I should take more pics of the cables/ routing up front and how I ran it under the car to be a more complete writeup... I will try to do that later when tonight in the garage. this was just a quicky cause I liked the new billet tie down setup I installed.
I bought that billet setup on ebay... it for optima battery's. I searched optima battery box. http://cgi.ebay.com/ebaymotors...=WDVW is the guy I found had the best price and quality... shipped fast
my dad/ brother own an union electrical shop here and so they got me some welding cable that super fine stranded that is a 2 gauge... got a thick *** heavy rubber jacket on it. I also was going to use stereo cable but decided to go this route cause the extra durability of the jacketing. stereo cable is ok you just have to run the wire more carefully, if it gets chaifed that clear polyester/ vinyl jacket is not quite as restistant to damage. btw mine is ran under the car and not through the inside.
run the biggest wire you can get to fit.. at least 2 imo but if you can fit as big as 0 and get it cheap... do it.
more to come...
Modified by twkdCD595 at 1:28 PM 10/13/2004
Modified by twkdCD595 at 3:34 PM 10/13/2004
Old Oct 13, 2004 | 11:32 AM
'00Accordster's Avatar
Default Re: (twkdCD595)
looks good man!!
Old Oct 13, 2004 | 12:03 PM
yeamans17's Avatar
Default Re: (95Accordster)
do you think you could email me a more specific write up of how its done that looks really good
Old Oct 13, 2004 | 12:19 PM
twkdCD595's Avatar
Default Re: (yeamans17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeamans17 &raquo;</TD></TR><TR><TD CLASS="quote">do you think you could email me a more specific write up of how its done that looks really good</TD></TR></TABLE>
I will try to be as complete and detailed as possible in a writeup later when I upload the additional pictures. hopefully that will help explain better, otherwise shoot me a pm it would probably be faster than e-mail.
95accordster: thanks for the compliment... I try to do things the best I can.
edit: just found out I am going to the st. louis cards game tonight though (WOOT!)... so... probably will be late tonight.
Old Oct 28, 2004 | 09:44 AM
twkdCD595's Avatar
well sorry about being a lazy ***, damn baseball games and whatnot.
anyways.
I uploaded a bunch more pics of the cable routing under the car and whatnot.
I am trying to kind of put together some info about the process but I am kinda skatterbrained right now. in the meantime if there is any specific questions feel free to ask.
Old Oct 28, 2004 | 03:35 PM
C_H_A_D's Avatar
Thats a good idea welding leads but the ones I see at work are bigger than 2 gauge but I like how you did that
Old Oct 28, 2004 | 04:47 PM
96jdmaccord's Avatar
Default Re: (mood513doom)
looks good i did the same thing but i used red 4 gauge wire and ran it inside the car under the carpet from the starter to the battery in the trunk, used 8 gauge from the fuse box to the starter, and 10 from the fuse box to the abs fuse box. The ground cable that goes to the tranny i put a 4 gauge wire there too. I am planning on up grading to a optima yellow top battery soon. Will post pictures when cardomain stops acting up.
Old Oct 28, 2004 | 06:58 PM
1illAccord's Avatar
Default Re: (96jdmaccord)
nicely done =] looks hot!! what what.
Old Oct 28, 2004 | 10:18 PM
twkdCD595's Avatar
Default Re: (1illAccord)
werd, thanks guys!
anyone with pics and whatnot of their own setup... feel free to add it!
Old Oct 29, 2004 | 05:12 AM
F23Coupe's Avatar
Looks awesome. Now the biggest question is: does your car feel more balanced in handling after the relocation? Is it worth it? Thanks.
Old Oct 29, 2004 | 06:22 AM
TypeRKoncepts's Avatar
i just used the manley battery relocation kit, 45 bucks.
Old Oct 29, 2004 | 11:00 AM
twkdCD595's Avatar
Default Re: (F23Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F23Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Looks awesome. Now the biggest question is: does your car feel more balanced in handling after the relocation? Is it worth it? Thanks.</TD></TR></TABLE>
feels better but I cannot say for sure how much it really helps... the *** of the car does not feel like its sliding as much through very hard turns. I have not really been pushing it to try and test though, cause it is so hard brakes, tires, etc.
Eskimo007
Honda Civic (2001 - 2005)
Apr 2, 2008 10:08 PM
ben_eg6
Oct 5, 2004 04:04 PM
elmalouno
11
Sep 20, 2004 10:01 AM
sakthi
Aug 22, 2004 08:10 PM
DsITR
Apr 5, 2004 11:45 PM
