need some help with oil pans????
Old Oct 13, 2004 | 09:31 AM
JAYGSR's Avatar
Default need some help with oil pans????
i would like to no if b16a 92-95 sirII and a b18c1 oil pans are the sam and if the gsr oil pan will fit and work on my b16a sirII. because mine is dented and i have
a blown gsr motor so i was wondering if i could swap them......
Old Oct 13, 2004 | 09:41 AM
smart monkey's Avatar
Default Re: need some help with oil pans???? (JAYGSR)
b16a and ls are the same. the gsr and ITR are the same. tomy knowledge you can't use a ls or b16a on a gsr or r cause it is too shallow and won't clear the girdle however you can use a gsr or ITR on a ls or b16a but you need to use the gs or itr oil pickup.
hondaon18's
Sep 29, 2007 05:22 AM
mbdelsol
Feb 9, 2006 05:14 PM
tslag
Aug 19, 2003 05:32 PM
supergreenNA1
Mar 9, 2002 04:10 PM
