99 si rev limited at 7900 wtffff!?
Old Oct 13, 2004 | 08:01 AM
Champ White EJ8's Avatar
Default 99 si rev limited at 7900 wtffff!?
we put an autometer tach in and its exactly the same... do u think a p28 is in it or maybe the cam timing is off since there r cam gears in there?
Old Oct 13, 2004 | 08:19 AM
aznboysrfr's Avatar
Default Re: 99 si rev limited at 7900 wtffff!? (DC2TEG9600)
what did you expect?
Old Oct 13, 2004 | 08:34 AM
HybridEJ1's Avatar
You have a B16A2 with a P28? Please tell me it's chipped.
Old Oct 13, 2004 | 08:57 AM
idk if its in there, i think is a stock ecu but i havent looked yet.. some1 todl me b4 2 getta new tach, so we put 1 in and its the same.. does any1 think its the timing or na?
Old Oct 13, 2004 | 09:00 AM
b20izzle's Avatar
addin a tach isnt goin to raise ur rev limiter
Old Oct 13, 2004 | 09:05 AM
RVCA97's Avatar
Default Re: 99 si rev limited at 7900 wtffff!? (b20izzle)
get it chipped
Old Oct 13, 2004 | 09:08 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20izzle &raquo;</TD></TR><TR><TD CLASS="quote">addin a tach isnt goin to raise ur rev limiter</TD></TR></TABLE>
I dont think he thought that, Someone probably told him to try a new tach to see if the original one was off.
Anyway. Check the simple stuff first. Make sure you have the correct ECU. That is simple stuff that you can check BEFORE you make post about stuff. Problem solving is key. That way when you ask the question, there is more background for people to go off. So check what ECU you have if you arent sure which one it is.
Old Oct 13, 2004 | 09:10 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 99 si rev limited at 7900 wtffff!? (tribalnx)
Pull the passenger side lower kick panel off and look to see what ecu you have in there. It should be a P2T and it's basically square. The P28 is rectangular and may be causing the rev limiter to kick in at 7900 rpm, if you have the correct ecu in there, then your tack(s) are off. It is NOT a timing issue in any way shape or form.
Old Oct 13, 2004 | 09:11 AM
99cxrico's Avatar
what does a 99 si supposed to redline at, I thought it was 8k. 7900 would be the same.
Old Oct 13, 2004 | 09:12 AM
Default Re: 99 si rev limited at 7900 wtffff!? (00Red_SiR)
thanks, its not my car i gotta jdm teg, its my cousins and i dont see him much so im just workin with what im given, thanks alot guys
Old Oct 13, 2004 | 09:13 AM
CivicSiR's Avatar
Default Re: 99 si rev limited at 7900 wtffff!? (99cxrico)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99cxrico &raquo;</TD></TR><TR><TD CLASS="quote">what does a 99 si supposed to redline at, I thought it was 8k. 7900 would be the same. </TD></TR></TABLE>
actually 8000-7900= 100...therefore there is a difference
Old Oct 13, 2004 | 09:14 AM
00Red_SiR's Avatar
All Motor Mentor
They redline at 8k and hit the rev limiter at 8200 rpm
Old Oct 13, 2004 | 09:23 AM
yah, i just wanted 2 make sure it wasnt anything big b4 i told him 2 take out his ecu, any1 sellin a b16 head?
Old Oct 13, 2004 | 09:26 AM
Kamin's Avatar
well considering the engine stops making power long before 7900 i really wouldnt complain, you are only making the car slower by going that high.
Old Oct 13, 2004 | 09:30 AM
Default Re: 99 si rev limited at 7900 wtffff!? (Kamin)
hes got crower valvetrain, aem gears, aem cold air, dc headers, apexi exhaust... i think he might be able 2 go a lil higher the 7800...
Old Oct 13, 2004 | 09:32 AM
Kamin's Avatar
cams?
also intake header exhaust and cam gears have nothing to do with RPM
Old Oct 13, 2004 | 09:35 AM
WAFFLES's Avatar
any cels?
Old Oct 13, 2004 | 09:58 AM
SiKid86's Avatar
Default Re: 99 si rev limited at 7900 wtffff!? (WAFFLES)
yeah 99 si is a 8200 rev limit.
f-it3
Jan 30, 2006 01:29 PM
B16Civic93
Nov 27, 2004 07:04 AM
Team 4
Dec 30, 2003 10:00 PM
integra-modder
Oct 27, 2002 01:44 AM
TRuST
May 7, 2002 11:24 AM
