messed up the threading on my short shifter
like title says...i smashed the threading on the short shifter while installing it its just mininal but i was wondering where i could get a thread kit to rethread that thing...now im just driving with the stick.
you will need a 10mm die. 3\8 is standard while the 10 mm is metric. They are different.
I picked up a single die from napa and used a big ol' wrench to turn it on and rethread the top of a short throw.
You can probably pick up a whole tap and die set from any hardware store for maybe $30-50? good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnis »</TD></TR><TR><TD CLASS="quote">you will need a 10mm die. 3\8 is standard while the 10 mm is metric. They are different.
You can probably pick up a whole tap and die set from any hardware store for maybe $30-50? good luck.</TD></TR></TABLE>
i pick my tap and die set for $25 dullers..at the bargin store..
the one on my b&m was standard. it was 3/8". i assume the stock shifter would be metric like everything else on the car though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">i just cut mine and jam the **** on it. works fine.</TD></TR></TABLE>
89civich22
14
Apr 8, 2006 06:58 PM
