best way to bond two pieces of brass ??
Old Oct 13, 2004 | 06:47 AM
Dan GSR's Avatar
Default best way to bond two pieces of brass ??
brazing them together is no good
JB weld works so so....kinda iffy
can brass be welded?
Old Oct 13, 2004 | 10:10 AM
kb58's Avatar
Banned
Default Re: best way to bond two pieces of brass ?? (Dan GSR)
Solder?
Old Oct 13, 2004 | 12:01 PM
turbodude's Avatar
have it brazed professionally, it should hold up great.
Old Oct 13, 2004 | 01:05 PM
h22 civic's Avatar
Default Re: best way to bond two pieces of brass ?? (turbodude)
brazed.. 15% silver solder hold 300psi of water i dont think you would be doing more then that make sure you clean the brass good with some emery cloth or 3m and use some BRAZING FLUX (its white) not soldering flux i gaurentee it
yes it could be welded
Old Oct 13, 2004 | 03:00 PM
Bailhatch's Avatar
Default Re: best way to bond two pieces of brass ?? (h22 civic)
yup brazing it prime
Old Oct 13, 2004 | 03:58 PM
kb58's Avatar
Banned
Default Re: best way to bond two pieces of brass ?? (Bailhatch)
Except that he said, "brazing is no good," hence my solder suggestion.
Old Oct 14, 2004 | 06:27 AM
79 civic's Avatar
Default Re: best way to bond two pieces of brass ?? (kb58)
brazing has a much higher tensile strengh than anything else you could do for brass. try some dev-con though
when done properly brazing is stronger than a weld in some aspects
Old Oct 14, 2004 | 07:56 AM
kb58's Avatar
Banned
Default Re: best way to bond two pieces of brass ?? (79 civic)
I agree, but he said it was "no good", whatever that means. It's not up to us to tell him to use something he says won't work. The original poster could be helpful by explaining why it won't work...
Old Oct 14, 2004 | 08:05 AM
Dan GSR's Avatar
didn't realize that brazing could be that reliable
i'll have to look into trying that
Old Oct 14, 2004 | 08:23 AM
turbohappy's Avatar
A lot of older race car frames are brazed together.
Old Oct 14, 2004 | 08:47 AM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">didn't realize that brazing could be that reliable
i'll have to look into trying that</TD></TR></TABLE>
How come you said brazing was no good? What's the application. FWIW, brazing is VERY strong because the contact area is so large.
Old Oct 14, 2004 | 11:55 AM
h22 civic's Avatar
he prob didnt clean too wellwhat exactly is needed to be done and i could give you a 100% positive answer ive be en brazing every day for the last 16 years
niceprelude
Detailing
16
Mar 5, 2009 07:22 AM
Slatelude
Jan 30, 2006 11:00 PM
silentblackhat
Jun 1, 2005 11:58 PM
beaterman
Audio / Security / Video
Mar 10, 2005 08:27 PM
leadtrum
Jun 8, 2003 05:37 PM
