Castrol RS 10w60
Old Oct 13, 2004 | 04:31 AM
Takashi1978's Avatar
Default Castrol RS 10w60
Been on a tight budget lately.Here is the story.
Malaysian market:
Mobil-1 = crap
Shell = full syn only 15w60
I use Motul 300v 5W40 very nice and doesnt burn as much.But expensive.
Thinking of Castrol but they only one syn model here and it's the 10w60.
Will running "60" be too much to handle for a B16B?
Any pros or cons?
Old Oct 13, 2004 | 04:46 AM
jond's Avatar
Default Re: Castrol RS 10w60 (Takashi1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takashi1978 &raquo;</TD></TR><TR><TD CLASS="quote">Will running "60" be too much to handle for a B16B?
Any pros or cons?
I wouldnt even run 60 weight in my worn out 289 V8. A engine would have to be seriously loose to use something that heavy. I would think it would blow up a honda engine.
Old Oct 13, 2004 | 05:03 AM
1GreyTeg's Avatar
Default Re: Castrol RS 10w60 (jond)
I run 10W60 Agip racing blend full synthetic.
Been using it for 2 seasons now. Absolutely No consumption issues anymore. My car is Not a daily or cold weather driver, is always warmed up properly before any driving, the fluid levels are always checked before driving, is only used for track and autcross and the occasional jaunt on a Sunday.
I have not yet had a chance to test the oil but will when I swap plugs and at the same time check compression but that'll be a winter to spring project.
Read on this site for more good testing and information on oil: http://bobistheoilguy.com/
Old Oct 13, 2004 | 05:35 AM
Bbasso's Avatar
Just to toss up an experience...
I used 15-50M1 for just shy of 2k miles and thought the car felt like it was draggin its ***. The crossover into Vtack was slow and lacked the pop that it usually had. The caR was slow, Opie was rolling me hard
At the next oil change I switched back to 10-30 and the caR felt alive and willing to go.
Old Oct 13, 2004 | 05:40 AM
hype r 555's Avatar
Default Re: Castrol RS 10w60 (Bbasso)
I'm running vr-1 racing oil - 20w50, my motor loves it.....Is your motor stock or?
Old Oct 13, 2004 | 05:58 AM
Bbasso's Avatar
Default Re: Castrol RS 10w60 (lsed-eg)
Yup stock...
Old Oct 13, 2004 | 06:00 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
Havent we been over this already?
If the car's primary use is extended track sessions (over 30 minutes) or racing, then its a good option to have.
I wish I could get the 10w40 Castrol RS here, but the 0w30 is doing fine (although its thicker than 10w40 M1).
Old Oct 13, 2004 | 06:09 AM
sylvain's Avatar
I drive on my R Castrol RS 10W60, the car have now 152000kms and no oil burn and run very fine.
Old Oct 13, 2004 | 06:50 AM
RedR's Avatar
Default Re: (sylvain)
i run castrol TWS 10w60 on the summer and after 3k miles it needs 1L but it handles better the hot days of summer than my 0w40 (winter oil)
Old Oct 13, 2004 | 07:50 AM
jond's Avatar
Default Re: Castrol RS 10w60 (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Oh soo many times....
Yeah, racing oil and street oil are two totally different things.
Even for racing though, I would think a 60 weight would throw the oil pressure through the roof.
Old Oct 13, 2004 | 07:52 AM
.RJ's Avatar
.RJ
Yeah, racing oil and street oil are two totally different things. </TD></TR></TABLE>
Castrol RS (and the "GC" 0w30 I use) are not racing oils. They're street oils, multi-grade, with detergents for street use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Even for racing though, I would think a 60 weight would throw the oil pressure through the roof. </TD></TR></TABLE>
Would think........... Look at a temp/viscosity chart. At elevated oil temps, a 50-60w will give you the same viscosity, if not thinner, as a 30-40w driving around town or on the highway, depending on the brand, etc.
Old Oct 13, 2004 | 07:55 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Castrol RS (and the "GC" 0w30 I use) are not racing oils. They're street oils, multi-grade, with detergents for street use.</TD></TR></TABLE>
Would you use a 60 weight on the street?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Would think........... Look at a temp/viscosity chart. At elevated oil temps, a 50-60w will give you the same viscosity, if not thinner, as a 30-40w driving around town or on the highway, depending on the brand, etc.</TD></TR></TABLE>
Maybe. I wouldnt run it without an oil pressure gauge though. I would rather burn oil than blow a head gasket or main seal.
Old Oct 13, 2004 | 08:00 AM
.RJ's Avatar
.RJ
Would you use a 60 weight on the street?</TD></TR></TABLE>
Sure, although my car sees very little street use (mostly driving to the track).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Maybe. I wouldnt run it without an oil pressure gauge though. I would rather burn oil than blow a head gasket or main seal.
You're implying that you'd blow a head gasket with a 60wt oil? Doesnt sound feasible at all.
Old Oct 13, 2004 | 08:14 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">You're implying that you'd blow a head gasket with a 60wt oil? Doesnt sound feasible at all.</TD></TR></TABLE>
I would think running double the recommend weight would have the same consequences as putting in too much oil. Oil pressure will be high, and all gaskets and seals will be strained. I know a kid in college who blew his engine up by putting too much oil in it. I know its possible. Not worth the risk IMO.
Old Oct 13, 2004 | 08:19 AM
1GreyTeg's Avatar
Please make it stop.
Guess mines a veritable time bomb since it also currently has the HAMP mini filter on it And for heavens sake no OPG.
Gauges are on my list for this winters projects but not because I'm concerned that the oil will blow a gasket. Solely to keep tabs on the car at the track.
If though you're concerned and curious about the pressure of this oil in a B18C5 that is also virtually a track only car (albeit autocross), contact Rodney. He and I have been running the same weight and oil for just about the same length of time now but he has a dizzying array of gauges, lights, whizzers and dials to keep tabs on his hatchcrap.
Old Oct 13, 2004 | 08:27 AM
.RJ's Avatar
.RJ
Overfilling with twice as much oil is far, far worse than using "double" the weight - but oil viscosities are NOT linear!
You're really reaching here. Do some research on the subject.
Old Oct 13, 2004 | 08:35 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">You're really reaching here. Do some research on the subject.</TD></TR></TABLE>
Apparently people running 60 weight in b series engines are getting around 70psi under wot. Thats not too bad. So anyway, I'm wrong, your right.
I still wouldnt use it though
Old Oct 13, 2004 | 08:37 AM
.RJ's Avatar
.RJ
All depends on the intended use and temp range the oil will see.
0w30 works fine for me, for now, but I would like to try the 10w40 if I could get my hands on it.
Old Oct 13, 2004 | 09:10 AM
Thanks guys for all the info.
My car is a stock B16B with i/h/e and Mugen gasket.
Daily driven car which wont see the track.
I live in Malaysia which will see 70-90f weather temps all year round.
Old Oct 13, 2004 | 09:42 AM
DutchITR1689's Avatar
I use Castrol RS Syntec 10W-60 in the summer and on the track. For 3 years already... No oil burning. Castrol Syntec RS 0W-40 for the winter.
Old Oct 13, 2004 | 11:55 AM
petrv's Avatar
Default Re: Castrol RS 10w60 (DutchITR1689)
I think you don't understand the XXwYY numbers well. IMO, 10w30 and 10w60 oils are the same in normal streed use. The 10w60 one is however way better, because it can handle much higher temperatures than the 10w30 one.
Old Oct 13, 2004 | 03:04 PM
Padawan's Avatar
Darth ModerVader
Default Re: Castrol RS 10w60 (petrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv &raquo;</TD></TR><TR><TD CLASS="quote">IMO, 10w30 and 10w60 oils are the same in normal streed use.</TD></TR></TABLE>
No, they aren't.
Old Oct 13, 2004 | 03:09 PM
uNF$@#!'s Avatar
Default Re: Castrol RS 10w60 (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
No, they aren't. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petrv &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, they are. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
anyone who thinks they are the same just isnt in the know
Old Oct 13, 2004 | 03:23 PM
emotionisdead's Avatar
Very Emergency!!
you are right they are not the same, but they are close. remember that the oil still starts out as a 10weight oil and then is supposed to raise viscosity as the temp increases. i have tried everything from 5w30 castol nad mobil up to 15w50 mobil and still burn through everything like no ones business. i am going to try the vr1 20w50 soon.
Old Oct 13, 2004 | 03:58 PM
Padawan's Avatar
Darth ModerVader
Default Re: Castrol RS 10w60 (Booyakasha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booyakasha &raquo;</TD></TR><TR><TD CLASS="quote">i have tried everything from 5w30 castol nad mobil up to 15w50 mobil and still burn through everything like no ones business. i am going to try the vr1 20w50 soon. </TD></TR></TABLE>
Oil consumption, in my opinion, isn't necessarily a reason to switch to a higher viscosity oil. Certain oils seem more prone to consumption than others, but if the consumption is very excessive, there are most likely issues with the motor itself.
