Changed rear brakepads a while ago. Now strange sound when going reverse.
Old Oct 13, 2004 | 12:06 AM
Pompiuses's Avatar
Default Changed rear brakepads a while ago. Now strange sound when going reverse.
I changed my rear pads and rotors a while back ago. When I'm going slowly in reverse and breaking gently there's a pretty loud sound from the rear brakes.
Anybody know what this might be, and how to fix it?
Old Oct 13, 2004 | 12:19 AM
Bbasso's Avatar
Default Re: Changed rear brakepads a while ago. Now strange sound when going reverse. (Pompiuses)
what kind of sound and how many miles on them?
Old Oct 13, 2004 | 12:29 AM
Pompiuses's Avatar
Default Re: Changed rear brakepads a while ago. Now strange sound when going reverse. (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">what kind of sound and how many miles on them?</TD></TR></TABLE>
Theres about 1000 miles on them. Almost brand new (Cobalt GT-Sports).
The sound is difficult to explain but it's not rasping or grinding. Just a clear loud sound when the pad comes in contanct with the rotor.
Only happens when going reverse. Brakes seem fine in any other way.
Old Oct 13, 2004 | 12:32 AM
Bbasso's Avatar
could it be just a friction noise...
If you go backwards and pull the e-brake up does it make the noise or only with the pedal?
Old Oct 13, 2004 | 12:53 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">could it be just a friction noise...
If you go backwards and pull the e-brake up does it make the noise or only with the pedal?</TD></TR></TABLE>
Just took the car out for a spin, and when the brakes are cold theres no noise in them at all. When they get heated up, they start making the noise when going in reverse, and only when using the pedal and not the e-brake.
There also quite a bit of sqeeling from the rear brakes when braking going forward, but the reverse noise sounds "worse".
Old Oct 13, 2004 | 04:06 AM
Philly_NBP_R's Avatar
you might need more brake quiet on the back of the pads...
Old Oct 13, 2004 | 05:07 AM
Nishant's Avatar
Default Re: Changed rear brakepads a while ago. Now strange sound when going reverse. (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">you might need more brake quiet on the back of the pads...</TD></TR></TABLE>
that should clear it up. i was getting horrible noise on mine. I put on the red brake quiet stuff and the noise was gone. try that
Old Oct 13, 2004 | 10:33 AM
Pompiuses's Avatar
Default Re: Changed rear brakepads a while ago. Now strange sound when going reverse. (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">
that should clear it up. i was getting horrible noise on mine. I put on the red brake quiet stuff and the noise was gone. try that</TD></TR></TABLE>
What is brake quiet? Where can I get it?
Old Oct 13, 2004 | 10:42 AM
Jon D's Avatar
Noice choice of pads by the way
Old Oct 13, 2004 | 02:59 PM
mstewar's Avatar
a lubrication.. goes between the pad and the shims..
should be able to pick some up at any auto parts store..
envee
Honda S2000
15
Feb 6, 2008 02:44 PM
DrewQ1
Jul 10, 2005 10:14 AM
MOVE OVER
Apr 6, 2005 07:53 AM
jdmstreethatch
Dec 28, 2004 03:03 PM
