difference between the LX and EX
I'm getting into Honda Challenge and just wanted to know what's the difference between the LX and EX besides the engine. Suspension, chassis, and etc because i have a LX and i'm running with H5 for now. But i'm also considering running in H4 with the civic EX guys so that means i would have to switch everything over from an LX to a EX. Thanks
I'm not sure what you mean by H4 or H5, and I assume you're talking about 96-00 Civics. In that case the EX comes with larger front brakes and most of the time rear disc brakes. EX also has a moonroof, correct me if I'm wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">only thing different, is the LX doenst have vtec or a sunroof</TD></TR></TABLE>
I read from another forum that the EX had rear disc brakes than drums.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongboyLS »</TD></TR><TR><TD CLASS="quote">
I read from another forum that the EX had rear disc brakes than drums.</TD></TR></TABLE>
all depends, i have a 93 LX i have rear drums, but ive seen LX's with rear disc. i think it was just the ABS models
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongboyLS »</TD></TR><TR><TD CLASS="quote">I read from another forum that the EX had rear disc brakes than drums.</TD></TR></TABLE>
92-95 coupes and sedans with ABS had 4 wheels discs. 96-00 all had front discs, rear drums even with abs. only the 99-00 si had non-abs discs in the rear.
Or rear discs
Or rear discs
<FONT COLOR="red"><FONT SIZE="8">The only '96-'00 Civics that have rear discs was the '99-'00 Si</FONT></FONT>
I think CDM '92-'95 EXs had rear discs...not sure though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red"><FONT SIZE="8">The only '96-'00 Civics that have rear discs was the '99-'00 Si</FONT></FONT>
I think CDM '92-'95 EXs had rear discs...not sure though</TD></TR></TABLE>
hes right...the 96-00 ex's did not come with rear discs, although i think it was an optional part if you choose to have it...i have a 96 civic ex w/ abs and it didnt come with rear disc brakes...
Modified by CivicEX96 at 9:43 AM 10/13/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic »</TD></TR><TR><TD CLASS="quote">I have a 93 EX Coupe w/ Disc in front and drums in back. So I bet is was an option.</TD></TR></TABLE>
EG EXs came with disks. The EKs did not. The only option for the EK was ABS, there was no disk option.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">
finally correct information...and like people said, VTEC and a sunroof is the difference.
THE DIFFRENCE BETWEEN A LX AND EX. THE LX HAS A NON VTEC ENGINE AND THE INTAKE MANIFOLD IS ALSO DIFFERENT. THE ECU IS DIFFERENT THE HEADERS ARE ALSO DIFFERENT THE CAT IS ATTACHED TO THE HEADER. THE LX HAD THE BLACK SIDE MOLDINGS AND MIRRORS WHILE THE EX ARE THE COLOR OF THE CAR. THE EX ALSO HAS THE POWER SUNROOF AND ALSO IT HAS THE 6 SPEAKER SYSTEM HAS TWEETERS, 6 1/2 SPEAKER ON THE DOORS AND 6X9 ON THE REAR AND ALSO HAS ABS
The EX difference is you bend over further at the dealership to grab your ankles for the D16y8 motor. and yeah it comes with a hole in the roof and some power windows and door locks. Mine is 1998 ex coupe and it has drums in the back, i have never seen one with discs, are they out there???
YOU WILL PAY MORE FOR AN EX MODEL THAT YOU WILL MOST LIKELY DROP THE D16Y8 ENGINE AND DROP A B16 OR B18 ON IT IF THAT IS THE CASE GET AN INTREGA GSR OR A TYPE R
<U>1992-95 Honda Civic LX 4DR Sedan Specs</U>:
1.5L SOHC 102hp 98lb-ft torque D15B7
5-speed Manual Overdrive
optional 4-speed Automatic Overdrive
13x5 pressed steel wheels w/ full covers
(gained 14x5 in 94)
175/70R13 tire
(gained 175/65R14 tires in 94)
power windows
power mirrors
power door locks
power steering
tilt steering
cruise control
tachometer
center console armrest w/ storage compartment
AM/FM high power stereo cassette with 4 speakers
quartz digital clock
cargo area light
coin box
beverage holder
fold down rear seatback w/ lock
adjustable front seatbelt anchors
rear defogger
driver SRS airbag
( gained passenger airbag in 94)
10.3in. front vented disc brakes
7.9in. rear drum brakes
optional ABS w/ 4-wheel disc brakes (9.4in. rear disc brakes)
21.0mm front anti-roll bar
1992 Honda Civic LX 4DR Sedan pictured below:
<U>1992-95 Honda Civic EX 4DR Sedan Specs</U>:
adds to LX:
1.6L SOHC VTEC 125hp 106lb-ft torque D16Z6
14x5 pressed steel wheels w/ full covers
175/65R14 tires
moonroof
air conditioning
some paint-matched trim
standard ABS brakes
standard 4-wheel disc brakes
13.0mm rear anti-roll bar
1995 Honda Civic EX 4DR Sedan pictured below:
(gained 14x5 in 94)
175/70R13 tire
power windows
power mirrors
power door locks
power steering
tilt steering
cruise control
tachometer
cargo area light
coin box
beverage holder
rear defogger
driver SRS airbag
adds to LX:
175/65R14 tires
moonroof
air conditioning
standard ABS brakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aldotyper »</TD></TR><TR><TD CLASS="quote">YOU WILL PAY MORE FOR AN EX MODEL THAT YOU WILL MOST LIKELY DROP THE D16Y8 ENGINE AND DROP A B16 OR B18 ON IT IF THAT IS THE CASE GET AN INTREGA GSR OR A TYPE R</TD></TR></TABLE>
TURN OFF YOUR CAPS LOCK....and shut up...this is an EG/EK forum, how you gonna talk about an Integra in here...by the way Integra are heavier than civics.
[QUOTE=94JDMEG
standard ABS brakes
[/QUOTE]
thats all i needed to know since everything you mention i have already ripped out of the car.
LX race car is having a make over to a EX to run in H4!
standard ABS brakes
[/QUOTE]
LX race car is having a make over to a EX to run in H4!</TD></TR></TABLE>
<FONT SIZE="5">WTF IS H4?!</FONT>
LX race car is having a make over to a EX to run in H4!</TD></TR></TABLE><FONT SIZE="5">WTF IS H4?!</FONT>
ok I think I know whats confusing everybody. Some of you are talking about the 96-00 and some are talking about the 92-95's. Diffs between 92-95 ex/lx is different that the 96-00 ex/lx.
get your generations straight.
