Having problem with the tail light/license frame light fuse kept blown, Sure need help!!!!!
This thingy really bothering me, I have a 99 honda civic, and my tail light/license light fuse kept blown. I changed the fuse after being pulled over, and it works all right for couple days which means it blew again!!>< Just changed another fuse and blown suddenly right after. I read post about wire harness from aftermarket headunit may cause the problem, and I did install a new headunit on my car not too long ago. I read couple posts here about the issuse, but I still need a specific solution just for the license/tail light(only problem). I was wondering if you guys can help me out on that and tks alot!!!
By the way: After installed the headunit, the dimmer function seem not working properly, that when I turn on the headlight, lights for ac/headunit/defrost just blinks, and it stables when I turn brightness control for the dash to some point so I didn't hook up the orange wire and have taped all the unuse stripped wires behind the headunit, I guess I will have to check it again. Still, any idea to solve the problem!?
slowslow
Nov 7, 2005 02:51 AM
